I did notice that the headers in AVI 1.0 files created by AviDemux and VirtualDub are a little different. The differences should have been parsable by a properly written program but maybe your player makes assumptions about the location or size of certain fields.
If you want to see the differences for yourself you can use the Hex editor in VirtualDub along with its RIFF chunk tree viewer.
Results 31 to 32 of 32
Recommend Blu-ray / DivX Certified player
By culttvguy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 16th Feb 2012, 08:24 -
Divx certified DVD player help...
By mjl1297 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 30th Apr 2011, 10:48 -
Would Philips be #1 certified DivX DVD Player?
By rocky12 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 20th Nov 2008, 21:12 -
Divx Certified dvd player won't recognize 16x9 aspect ratio
By maca in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 12:48 -
Is there a difference between a Divx player and a Divx certified player?
By Hank Kinsley in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Jun 2007, 12:30
