Hello...
I could use a fix!
I created a MPEG2 of Evolution and I forgot to cut it in two for 2 cds using TMPGnc. Anyways I'm stuck with this huge MPEG. My question to anyone is whether I can still make it fit using Nero. Heck, I even bought the MPEG-2/SVCD-Encoder patch from Ahead thinking that was going to help.
The movie is the usual 90min. It would be nice to fit it on one cd with good qual. I'd appreciate a line or two. Thanks
buy a 99 min cdr as theres no way youll fit 90 mins onto a 74 or 80 min disk or use tmpgenc to cut it in half and use 2 cds but i think youll need the mpeg2 codec in the tools section to open mpeg 2 files in tmpgenc
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 4th Jan 2011, 00:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 06:08 -
Virtualdub - Edit without re-encoding (except at edit point)
By itsonlyme in forum EditingReplies: 2Last Post: 26th Feb 2010, 06:59 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 11:05 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 14:13
