in the PICTURE SETTINGS of my LCD TV it has the following which arent explained in the manual..
1. Noise Reduction = off / low / medium / high
2. Film Mode = on / off
No matter what i put these on theres no change whatsoever to the picture or its quality...
what are they?
And you didn't think it would be helpful to mention your make and model of LCD TV because ... ?
Best guess - Film mode might possibly be some way to display an image in 24 fps.
Noise reduction is useless in high quality video sources like DVD or even clean cable TV feeds, so I'm not surprised that this feature makes no difference. It might be useful for videotapes I guess. -
Noise reduction must be for the aerial analogue broadcasts. It might help with VHS sources too. Sometimes, it also helps with VCDs and very compressed DVB channels.
Film mode is usually a manufacturer's preset for watching movies. A feature that nobody uses. -
What does the manual say about "film mode" ?
It could be turning inverse telecine detection on and off.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
need method for video noise reduction
By codemaster in forum EditingReplies: 2Last Post: 1st Jan 2012, 18:10 -
Speaking of noise reduction, what is this?
By takearushfan in forum RestorationReplies: 11Last Post: 5th May 2010, 22:14 -
HDTV/LCD displays: deinterlace and noise reduction review/comments
By vhelp in forum ComputerReplies: 0Last Post: 15th Nov 2009, 18:54 -
Noise reduction
By Geevim in forum RestorationReplies: 3Last Post: 5th Nov 2007, 07:23 -
Video Noise Reduction ----> H E L P
By wxyz in forum DVD RippingReplies: 14Last Post: 21st Jun 2007, 20:22
