I have a desktop PC that I recently rebuilt to be a HTPC with a wireless laptop client and a MediMVP as a wired thin client. The HTPC runs GBPVR as the media center prog.
Prior to rebuild, everything worked fine. However, now, whenever making a recording or watching live tv, I find the picture flashes a white/black dashed line horizontally through the middle of the picture briefly every few seconds. I took a recording, threw it up in Vegas Pro and found this frame as a good representation of what is happening. The flash only lasts for a split second and that is it and only happens periodically.
Any ideas, thoughts, etc.? The capture is obviously mpeg2.
Thanks in advance!
What seeing look like Closed Caption embedded in the wrong place this problem is with TV Broadcaster or Discovery Channel it self.
I appreciate the help SHS. After my post and from my research, I thought that it was maybe closed captioning. I just thought it was supposed to be at the top. But, if Dish or Discovery are embedding it incorrectly, then it sounds like, based on your post, this is the problem.
Thinking about it, I had noticed a small static-like line through the center of my non-PVR receiver and just thought it was some satelllite interference, etc. However, it now appears that it is a problem with the CC embedment. The MPEG encoding must just really intensify the effect.
Thanks again!
Using S-Video To Capture Into Hauppauge 1600 TV Tuner Card
By waldodiodio in forum CapturingReplies: 4Last Post: 1st Nov 2010, 17:49 -
Analog Video Capture Hauppauge 1600
By jrtmouse in forum CapturingReplies: 6Last Post: 13th Aug 2010, 14:46 -
Power issue? Hauppauge 1600 only works when I disconect my video card
By John32118 in forum CapturingReplies: 4Last Post: 11th Jul 2010, 11:56 -
Hauppauge Wintv-HVR-1600 ClearQAM VLC capture
By rhijaen in forum CapturingReplies: 0Last Post: 25th Oct 2009, 20:53 -
Hauppauge WinTV HVR-1600 and 3rd party capture software?
By NukeyDoo in forum CapturingReplies: 7Last Post: 27th Sep 2007, 14:35
