I have some anime episodes and I want to cut the intro and the ending. The problem is that the intro doesn't appear until minute 5 more or less.
I tried using Yamb but it did not cut anything.
what can I use?
Here's a screenshot with video features
thanks a lot
Results 1 to 10 of 10
thank you
I have just tried it out but in the output audio is not synchronized.
Maybe I can demux audio and video and edit them separately with virtualdub?
What program can I use to demux? -
Thank you!
You were right, I wasn't using the key freames
Now the sound is synchronized
thanks a lot! -
I have the same problem as OP. I tried Avidemux (in both modes) but the output file stutters.
I also used mkvmerge to convert to mkv and used its split function, but same problem: output file stutters.
It's jinxed. The original mp4 file doesn't stutter at all (neither in VLC nor in my TV hardware player).
But as soon as I cut it, the output file stutters. WHY?
Any help much appreciated. Thank you!
input file MEDIAINFO:
Code:General Complete name : F:\video\comedy\buelentlive.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 1.65 GiB Duration : 1h 29mn Overall bit rate : 2 620 Kbps Writing application : Lavf52.63.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1h 29mn Bit rate mode : Variable Bit rate : 2 452 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 fps Standard : PAL Bits/(Pixel*Frame) : 0.237 Stream size : 1.54 GiB (94%) Tagged date : UTC 2010-08-21 12:42:09 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 1h 29mn Bit rate mode : Variable Bit rate : 165 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Resolution : 16 bits Stream size : 106 MiB (6%) Tagged date : UTC 2010-08-21 12:42:09
clarify what do you mean by "stutter" ? do you mean jerky playback ? or out of sync ?
only at the cutsite, or everywhere in the file?
have you tried mp4box (yamb) , or tsmuxer (wrap into transport stream) for cutting ?
have you tried the nightly builds of avidemux ?
http://avidemux.org/nightly/win32/ -
yes, jerky playback. It's NOT freeze frames, like when you play a high res video and CPU power is not sufficient, but the video is jerky/stuttering ... it's hard to describe visuals with words, but it looks as if playback was slightly non-linear and jumping back and forth between frames while advancing overall (e.g. frames 1,4,2,3,7,8,5,6,9,10,11,14,12,13 ...). It's just an un-educated guess.
throughout the whole videoonly at the cutsite, or everywhere in the file?
I just don't understand what could be the problem. Original audio and video stream is preserved, only the container changes. So the only thing which could be missing is container info as to the frame rate, etc. But I don't think this explains the stuttering playback.
I have never experienced this kind of issue.
Which information can I post to further diagnose the problem? -
output file MEDIAINFO:
Code:General Complete name : F:\video\comedy\buelentlive.mkv Format : Matroska File size : 18.2 MiB Duration : 1mn 0s Overall bit rate : 2 544 Kbps Encoded date : UTC 2011-07-01 22:22:41 Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Codec ID : V_MPEG4/ISO/AVC Duration : 1mn 0s Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : A_AAC Duration : 1mn 0s Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz Resolution : 16 bits
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
how cut MP4 video
By kyro32 in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2010, 16:31 -
How can I edit (cut) segments from a H264 AVCHD video without re-rendering?
By kmmoore in forum EditingReplies: 5Last Post: 14th Dec 2008, 13:51 -
Removing bad segments using program "Video Edit Master"
By risp73 in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2008, 16:52 -
Organize a DVD into segments for MP4 encoding
By Trac in forum User guidesReplies: 0Last Post: 24th Jul 2007, 02:38
