I've had some bad experiences using the Dazzle DVC170 (Platinum) (simply awful, stuttering and dropped frames, crashes, etc) and noticed it shared the same chipset as other, inexpensive PCI cards.
Are there brands to avoid? Specific chipsets known to cause problems?
I record live video directly to WME 9, and until a couple of months ago, it worked great with my TV Wonder Pro in Vista. Then unexplainable and baffling problems with the card showed up. How does a set up that worked flawlessly for 8 months suddenly go into the crapper? I keep the Vista machine isloated, off network-- so it wasn't an update gone awry or some malware or whatnot. It's the same as when I built it.
Anyway, I'm looking for a WDM driven capture card that uses a chipset known to work day in and day out. Suggestions?
Results 1 to 1 of 1
Reliable USB capture devices?
By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 20:32 -
No sound in WME with USB capture card
By bomb jack in forum Capturing and VCRReplies: 2Last Post: 25th Feb 2011, 04:40 -
PowerDirector 8 doesn't work with USB capture devices
By chris18 in forum Capturing and VCRReplies: 0Last Post: 10th Feb 2010, 07:28 -
USB capture devices vs USB tuner devices...... which are better for recording?
By True Colors in forum Video Streaming DownloadingReplies: 1Last Post: 31st Jan 2010, 16:04 -
Are there any devices that can capture 480p with component through USB or P
By Cyber Akuma in forum Capturing and VCRReplies: 7Last Post: 2nd Aug 2009, 03:29
