Dear Members,
I have a Toshiba Home Cinema System Model Number SD-43HK, what i need help with is the sound ajustment levels on each speaker.
The manual says you must press the button "Test Tone" on the remote. When the test sound comes through the speakers, you then must press the button "Level" then you can adjust the sound level for that speaker and so on.
The problem is that there is no "Level" button on my remote. They seem to have sent me the wrong Owners Manual.
Can anyone tell me how i adjust the volume level for each speaker as i can't remember how to do it.
Thanks.
Jabbashouse.
Speaker setup begins on page 31...what you are wanting is on page 34 of the manual: http://www.toshibaav.com.au/support/manual/DVDPlayer/SD43HK.pdf
Google is your Friend -
Hi,
Just tried that link you gave me and all it opens up is a blank page.
Thanks.
Jabbashouse. -
The link is just to an online manual. It shouldn't be any different than what you already have.
Also, the link works fine, but it is a pdf file, not a webpage. You need to install Adobe reader.Google is your Friend
Watch DVD on Fash USB Stick/Disk on Home Cinema
By mdagis in forum Newbie / General discussionsReplies: 4Last Post: 8th Apr 2010, 11:06 -
Can I use the 5.1 speakers from my home cinema system without the dvd play
By leeuk321 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 2nd Aug 2009, 18:29 -
home cinema
By aanfield in forum Off topicReplies: 4Last Post: 2nd Jan 2009, 12:25 -
Toshiba SD-43HK.
By jabbashouse in forum DVD & Blu-ray PlayersReplies: 5Last Post: 31st Jan 2008, 11:07 -
sony dvd home cinema
By matw79 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th May 2007, 15:16
