Hi how do I go about resyncing subtitle files?
For example, I have an AVI movie file and I have a subtitle file (.srt) for that movie, but not necessarily the same version. So all the subtitles are correct relative to one another, but it is just slightly delayed/slightly ahead of the lines in the movie file. So I want to find a way to fix the srt file so it syncs with the movie. Thanks
subtitle workshop! or Time Adjuster.
You can also use vobsub to adjust delay directly if you just are playing the video and sub on your computer. -
Sure. This is the first 6 lines
1
00:00:43,413 --> 00:00:47,008
- Ba nghĩ là nó có thấy ḿnh không?
- Không, nó không thể thấy ḿnh được.
2
00:00:47,184 --> 00:00:49,812
Nhưng tin ba đi,
nó có thể cảm thấy ḿnh theo dơi nó.
3
00:00:58,929 --> 00:01:02,956
Ba? Ô, đó là một con lớn đó ba.
Có một con lớn ở đây.
4
00:01:03,667 --> 00:01:04,691
Được rồi.
5
00:01:04,801 --> 00:01:06,393
Nó chui ra rồi.
6
00:01:06,937 --> 00:01:09,098
10-2. Lẹ đi con, con có thể câu được.
Syncing manually.......
By GwnLee in forum SubtitleReplies: 3Last Post: 14th Sep 2011, 10:46 -
Syncing timing with additional subtitles?
By architectofpain in forum SubtitleReplies: 0Last Post: 6th Mar 2010, 02:16 -
Syncing subtitles with MeGui after an AVS cut
By Homeless Ninja in forum SubtitleReplies: 0Last Post: 11th Feb 2010, 23:52 -
Basic Question about Attaching / Syncing Subtitles
By Seeker47 in forum EditingReplies: 2Last Post: 12th Dec 2009, 15:05 -
Syncing different amounts of subtitles?
By architectofpain in forum SubtitleReplies: 0Last Post: 23rd Apr 2009, 02:10
