    Sep 2007
    Pakistan
    I record dvds from Philips DVD recorder. To make Copies I use computer Dual core 2 Duo 2 GB Ram ASUS SATA DVD writer 160 GB SATA DRIVE with nero8. The problem is that when i make copies the video is excellent but the audio is not matching with video. The dialogues are slower than the video image. Plz tel me why this is happening.
    Thankz
    BAqar
    Are you using nerovision and reauthoring the video? Then you might get sync problems. If you must reauthor then try something else like Ulead DVD Moviefactory or Tmpgenc dvd Author.
    If you just want to make an exact disc copy it shouldn't be any difference at all, use for example imgburn.
