Hi,
I have movies in mpg format that I need to compress and chop. I can compress them into wmv, mpg or avi...it doesn't matter. I need to compress the videos at a rate of 10mb per min.
So far this is my method...
1. import mpg file into WMM
2. merge and slice files into clips that I find appropriate
3. put clips one at a time into the story board, and have WMM compress and convert to .wmv file
This has been a bit tedious, as I have to wait till each clip is compressed and converted before I can start the next one. Depending on the size of the whole movie there can be many clips to work through in this time consuming manor.
I would like to use WMM (or another program, even better if I can files!) to compress and/or convert the movie as a whole. Then load up the movie and chop it up in to appropriate clips.
Does anyone have a quicker process or some advice if there are some things I can tweak with WMM to make things go a little faster?
Thanks in advance
Astro
	You can do this all in virtualdubmod, it natively accepts .mpg (and other video formats)
 You can do all your edits (cutting out segments like commericals for example), you can even append several clips, then encode to something (like divx, xvid, wmv, whatever...) all in 1 program
 You can do this with avidemux too, which behaves similarly to vdubmod
 Another approach would be to use an mpeg editor like mpg2cut2 and crop out the segments you don't want (leaving you 1 big mpg) then import this into your encoder of choice
 Good luck
	You can also do your edits and batch them so you can then let it compress over night using virtualdubmod Read my blog here.
  Chop it up!?By cnknightro in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2012, 09:02
  How to chop n edit .m2ts file?By Bonie81 in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2010, 06:16
  Slap Chop...any good?By ron spencer in forum Off topicReplies: 14Last Post: 14th Jun 2009, 09:36
  MPEG2's @ 18,000 Bitrate - Need To Chop & Shuffle. Where To Begin?By EViS in forum EditingReplies: 1Last Post: 17th May 2008, 12:43
  How to chop out a section in middle of .flv file without reencodingBy Toastie in forum EditingReplies: 0Last Post: 15th Jul 2007, 19:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
