I've read that these are pretty effective combination when it comes to removing noise. The only thing is there was no documentation with the filters. Do I just leave them at the default settings? Does anyone have any tips when using these filters?
Use higher settings for more noise reduction, lower settings for less noise reduction. Use the amount that's appropriate for your material.
Be sure to judge the result at normal playback speed. You will often see artifacts at normal playback speed that weren't noticeable looking at single frames. In my opinion, most people use too much noise reduction.
please list the virtualdub filters to remove vhs tape video noise
By perfection in forum Newbie / General discussionsReplies: 6Last Post: 7th Jan 2020, 13:45 -
vertical jitter reduction filters?
By lordsmurf in forum RestorationReplies: 14Last Post: 26th Nov 2009, 03:19 -
Where can I find stock static & dynamic(moving) backgrounds? Free and P
By Tfp in forum EditingReplies: 4Last Post: 5th Jun 2008, 20:26 -
port forwarding and static/dynamic IP address
By Rudyard in forum ComputerReplies: 3Last Post: 21st Jan 2008, 17:53 -
Chroma Noise Reduction filter for Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 10:43
