hello
I need a device to:
- watch and record TV (record in good quality, programmably, to my hard drive)
- listen and record FM Radio (record in good quality, programmably, to my hard drive)
- view Teletext
in my laptop
can you suggest me please
- what kind of card should I buy (USB? PCMCIA? ExpressCard? any?)
- what kind of format it should record in order to have maximum quality?
- any other must-have features?
then if you have any specific recommendation, I d be grateful
thanks
I am located in Europe
the laptop has these ports:
- Ethernet
- USB
- ExpressCard
- an "Expansion Port" (???)
- PC card (type I and II) [I suppose this is PCMCIA card slot]
- Secure Digital (SD) Memory Card
- Secure Digital Input/Output (SD I/O)
- MultiMediaCard (MMC)
- Memory Stick (MS)
- Memory Stick Pro (MSP)
- SmartMedia (SM)
- xD-Picture Card (XD)
these are photos of the laptop's slots:
http://www.notebookreview.com/assets/10682.jpg
http://www.notebookreview.com/assets/10670.jpg
it's dual core T2050, 2GB RAM, 160GB disk, 945 Intel graphics card with up to 224 MB
thanks -
anyone please ?
at least to tell me if recording in MPEG-1 is better than MPEG-2 or DIVX?
if connection via USB is better than PCMCIA or Express?
thanks -
Which format you record to will vary depending on how you plan to use the files. Mpeg-2 will (generally) have higher quality than mpeg-1. Divx would be equal to mpeg-2.
Google is your Friend -
You will probably want a USB 2.0 TV/FM tuner device. I don't think you'll find a PC Card or PCMCIA TV tuner. Most DV (it looks like you laptop has a mini firewire port) devices don't have tuners either.
In theory, MPEG1, MPEG2, and Divx can all deliver about the same quailty. But in practice MPEG1 is used for low resolution (352x288) video and MPEG2 for higher resolution video. Divx may be used for either but it doesn't handle interlaced video as well.
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 16:15 -
Help laptop to tv
By celecon in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2009, 14:53 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 09:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 19:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2008, 23:56
