Hi, Searched and didn't find what I was looking for...
I have an HP 300c dvd burner. It has always worked fine and still currently burns dvd's just fine (if i can find a source one it will read). My major problem is that I can't get it to recognize any newer dvd discs. I can put an older dvd, or burned dvd in and it reads it right away. It used to read everything I threw in there and I reformatted my computer now its being ridiculously picky.
Example...
It will read varsity blues, ace ventura, predator immediately
but
The Punisher, Dodgeball, Anchorman it won't read. And probably 14/20 of my roommates collection it won't read.
Is there a software issue that possible here or did this burner bite the dust?
It is set to region 1 so you can eliminate that idea.
It may be an old burner, but it probably has only burned <50 discs in its lifetime and has had relatively little use. Lets here what y'all experts think about it.
As old as the drive is the laser could just be dying a slow death.
yeah I figured...I'm most likely going to buy a new pioneer anyway cause burners are so cheap nowadays but I was hoping I could maybe keep this puppy going for awhile longer
Any other ideas? -
Burn laser is dead. Been there, done that.
Just keep it for ripping discs that can be read or use it to burn cd-r's only.Originally Posted by kpaxfaq
Make sure the drive is in DMA MODE and not PIO MODE.
Here's a guide on setting to DMA MODE:
http://www.cdrlabs.com/forum/viewtopic.php?t=7625
http://www.cdrlabs.com/forum/viewtopic.php?t=6645 -
Welp I said F-it and went out to walmart and bought a lighton 20x dvd-r for 44 bucks. Backing up a dvd as we speak, we'll see how this baby runs.
sata dvd burner in older computer
By victoriabears in forum DVD & Blu-ray WritersReplies: 1Last Post: 1st Apr 2010, 02:28 -
Older FFmpeg encodes MUCH Faster than newer builds!?
By V1de0Luvr in forum Video ConversionReplies: 4Last Post: 25th Nov 2009, 08:33 -
Burner won't burn DVDs
By Nephilim in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jan 2008, 17:23 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
Internal LG DVD burner drive, all of a sudden not functioning
By ryangarfield in forum Newbie / General discussionsReplies: 10Last Post: 1st Jun 2007, 23:10
