Under the advanced tab in TEMPG under Source Aspect Ratio how do I know what to select?
Im doing a SVCD.
On the conversion guide it says:
It says "if your source is in 4:3 select 4:3 525 line(NTSC)" etc etc etc. how do I know what the "Source is"Select Source Aspect Ratio select 1:1 (VGA) (if your source is in 4:3 select 4:3 525 line(NTSC) for NTSC and 4:3 625 line(PAL) for PAL)
Thanx
Is your question how to know the size of the original video or what does source mean (in that case it would mean the size of the video you are about to convert)
the best setting in my experience is keep aspect ratio because you don't have to worry about streching it will put black bars on top and below(like a dvd) if it's not the right format... -
My question is do I leave it on 1:1 or do I change it?
Im ripping a dvd to svcd? -
http://www.vcdhelp.com/phpBB/viewtopic.php?t=77303&highlight=ratio
check this out it should help you -
1:1 is never appropriate for a dvd>svcd conversion. find out what aspect ratio your source is(dvd2avi, bitrate viewer etc...) and select that for source & 4:3 for ouput
Aspect Ratio Question
By rede96 in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2011, 04:17 -
Aspect Ratio Looks Different After Encoding VHS Source
By jrodefeld in forum Video ConversionReplies: 1Last Post: 2nd Jul 2011, 09:35 -
Aspect Ratio Question + Some
By Alexander4444 in forum Video ConversionReplies: 7Last Post: 9th May 2011, 02:17 -
By kelticvixen in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2009, 13:27 -
Aspect ratio question
By gallootjs in forum MacReplies: 4Last Post: 10th Mar 2008, 02:14
