I got a movie(avi) with subtitle(srt)
Same name, differ extension
After ConvertX2DVD, subtitle did not show up.
Could it be ConvertX2dvd?
I'd tried downloading a trial subtitle player and it played fine,
so that mean the sub(srt) is fine.
Is there a better apps that i can try?
Athlon II X2 2.9Ghz
4G ram, 500HD, Dual Boot Win7_64 & XP3_32, ATI HDTV WONDER -
Can you see the .srt file autoloaded in the breakout menu in convertxtodvd? Have a look at the subtitle options, did you check autoload subtitle?
Did you test the DVD files before burning? You might have the wrong type of software that can see subtitles
Or are you referring to a burnt DVD? Did you turn subtitles "on" for your standalone player?
You can try FAVC which basically does the same thing and is free. -
Thanks poison,
Stupid me, Yeaaa I forgot to turn subtitle on on the player itself.Athlon II X2 2.9Ghz
Subtitle problems using convertxtodvd
By gtorres001 in forum Authoring (DVD)Replies: 41Last Post: 3rd Mar 2012, 02:36 -
ConvertXtoDVD subtitle issue.
By Randwill in forum SubtitleReplies: 3Last Post: 7th Sep 2011, 11:01 -
ConvertxtoDVD - Subtitle #2 (subtitle) etc Coodec Tag "mp4s" Unsupported
By Simmons in forum Video ConversionReplies: 0Last Post: 10th Jun 2011, 07:36 -
ConvertXToDVD Subtitle encoded file?
By theamilien in forum SubtitleReplies: 0Last Post: 16th Aug 2010, 05:07 -
ConvertxtoDVD subtitle settings, how to get less space between sentences?
By DavidHazelnut in forum Authoring (DVD)Replies: 6Last Post: 18th Nov 2007, 22:10
