Hey guys, i did a search here on how to convert divx3 to divx5 but found nothing.
Here is my sitaution-
I have about 80+ video files with DIVX3 codec that i need to update to DIVX5. Reason being is that i just got a 360 elite, and it supports divx and wmv playback. So is there any easier way to convert from divx3 to divx5 other then using apps like tmpgenc, or even divx's own converter. This will take forever having to convert 80+ videos.
Thanks for any and all input!
Results 1 to 14 of 14
AutoGK or AVI Recomp are pretty easy to use but reconverting will take time. It might be enough to just update the avi fourcc to div4 using AVI FourCC Code Changer.
I found this modded version of ffmpeg on Doom9 that converts from Divx3 to Divx5 losslessly and is much faster than re-encoding (the file is linked about halfway down the page).
http://forum.doom9.org/showthread.php?t=85229&page=2
I've used it for over a year and it works great.
I modified the example batch file shown near the top of the page to use DivXMux to mux the files back together. I haven't yet experienced any AV sync issues with the converted videos. -
Vid-Kid - i downloaded the modded version of ffmpeg. but when i run the .exe, it opens up a command window, and then a bunch of text scrolls, and then the window closes. so i assume i have to run this through the CMD command, but ive never done anything like this so im not sure how to use this program, and i cant find any tutorials online of how to use it.
No. You do have to make sure you are in the same folder as ffmpeg though, or have a full path name in your commands.
Personally, I think you would be better off with AVI RecompRead my blog here.
I hate to state the obvious, but are you sure you HAVE to convert from Divx3? I have heard of players that won't play Divx3, but some will. My Philips DVP-642, hardly top of the line, will play them fine.
You also should realize that Divx3 was all we had at the time, but it did a pretty poor job overall. The quality was never all that good with Divx3 and your conversions to Divx5 are just going to make matters worse. You may or may not care/notice, but there will absolutely be some quality loss in this conversion, possibly quite noticeable.
If you're willing to buy the commercial Divx codec (http://www.divx.com), the free Dr. Divx encoder which uses it is very easy to use and offers enough features to satisfy most people. It can do batch encoding, which might simplify your life a little. Again, it is NOT free, so if the idea of spending $18.99 doesn't appeal to you, you'll have to use the other solutions suggested, which might take a lot more time. You can get Dr. Divx for free at http://www.drdivx.com but please note as I said that it ONLY works with the commercial Divx codec. -
OK, first of all, please note that this is just something that I threw together for my own use. Don't expect any fancy interface or anything. It is simple, but it suits my needs.
To make it a bit easier for you, I have zipped up the files that I use. You can download it here
http://www.divshare.com/download/3920041-61c
1. Unzip the files to a directory of your choice.
2. Copy an AVI that you want to convert from Divx3 to Divx5 to the directory and rename it to MOVIE.AVI
3. Double click on the file Convert_Divx32MP4_NAC.bat, which will transcode the video to Divx5, demux the audio unchanged to an MP3 file, and then re-mux the audio and transcoded video back together.
4. After the command window finally disappears, you should see a file in the directory called MOVIE_OUTPUT_MUXED.AVI. That is the finished file, so you can rename it to whatever you want. The original MOVIE.AVI file will still be in the directory.
You will also see a second batch file in the directory called Convert_Divx32MP4.bat. That requires a bit more explanation. I have a number of old music videos that were encoded as Divx3 with MP3 audio that have a variety of bitrates. Some of the audio was recorded at very low volumes. I play all my videos via my D-Link DSM-320 media player, which doesn't support Divx3 and some of the MP3 bitrates that I have found in the videos. Also, I hate having to turn the volume up and down on my TV because the audio in the AVIs are all over map.
To fix the audio, I extract to audio to WAV format, maximize the volume, and convert it back to MP3 at a bitrate that my media player likes. The Convert_Divx32MP4.bat file handles the audio conversion as well as the video transcoding. To use it, you will also need to install Avisynth, which I use to decode the audio to WAV. The steps to use Convert_Divx32MP4.bat are the same as those for Convert_Divx32MP4_NAC.bat above.
Hope this helps. -
I believe Dr. Divx can be used with the free divX codec, jman, because that's what I've been using for a couple days now and I never paid anything. I think some options are disabled, however. The "insane" setting and bitrates higher than 4000, or at least those options don't appear to be available to me. Don't need them (at least not yet) so it isn't a problem.
-HD -
Vid-Kid , when i go to download from the link, it says access forbidden
thanks sooooo much vid-kid. it worked, and it only took three minutes for one episode. i appreciate all your effort.
DivX3 to DivX5 or XviD?
By Ogilvy in forum Video ConversionReplies: 5Last Post: 13th Dec 2013, 19:24 -
Which video players can handle DivX5 files the best?
By True Colors in forum Newbie / General discussionsReplies: 1Last Post: 29th Aug 2011, 11:06 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
