Not true, it depends on where you are and where you want to put it. In the UK you have to apply to the local council for what is called planing permission if you want to build or alter a building. The rules are different in different areas. It is also different depending on where you want to mount the dish. If you want to put it on the front of a house in full view of the road, you MAY have to ask permission for anything larger than 90cm. If you want to mount it on the back where it can't be seen, you PROBABLY won't need permission. If you want to mount it in the garden, and not attached to the house at all, you WON'T need permission (unless you intend mounting it on a base greater than 30 square meters).Originally Posted by SatStorm
If you live in an area that is designated as a conservation area, in an old cottage for instance, you may not even get permission for any dish if the local council feel it will spoil the appearance of the area.
Results 31 to 33 of 33
In the U.K. on the cities you need permission on all cases to install dishes larger than 90cm on buildings. The law exists since 2001 (before 2001 only 65cm allowed without permission...)
Installing dishes to the ground is another issue. I don't know many people to have a Garden in the center of London and use it for installing 3 meter dishes there!La Linea by Osvaldo Cavandoli
HDSuisse went V2.6. Ugh! I'm not a suisse citizen.Originally Posted by SatStorm
You have a point of course with the dish size.
I wish it were so with the german laws.
PC live feed - how-to and hardware
By don.johnson in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 21:53 -
Feed and record simultaneously?
By nkordyjaka in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Oct 2010, 23:15 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 19:02 -
Sky HD box - is the upscaling any good?
By snadge in forum DVB / IPTVReplies: 0Last Post: 23rd Feb 2008, 17:33 -
Feed the world
By guns1inger in forum Off topicReplies: 0Last Post: 26th Nov 2007, 02:44
