Hi! I just converted some avi files to dvd using FAVC and imgburner. I did 4 files at the same time. I put the disk into the dvd player to check if it worked and looked at a about a minute of each one, and they seemed great. Later, I watched the first one, and after a few minutes something didn't seem right. I started noticing that the lips were moving, but the sound was late, like in those old Kung Fu movies. As the video went on, the interval between video and sound grew. I watched into the third video, and by then the interval was about 6 seconds. What can I do to correct this? I don't want to burn any more of these files until I can fix this problem. Is there some program I should use to do something with the sound before I use FAVC? When I finished the process with FAVC, the AUDIO_TS file was empty. Is that the way it's supposed to be? The audio settings in FAVC were the default ones; AC3, Retain if Present, and Aften. Any help would be greatly appreciated. Thanks.
	There's a lot of reasons, but it can be due to VBR audio on your source AVI files. Run the AVIs through Avi_Gain_Regular.bat (look in the Completed folder for the Normalized AVIs)
 https://forum.videohelp.com/topic314909.html
 It'll make the audio CBR, which will hopefully take care of the issue. No guarantees, though. Play the normalized AVI files through and see if the sync is still good.
 Before burning your DVD, play the vob files on your PC to make sure the sync is good.
	Back again. That avi_gain is an amazing program to watch run in the command window, but, alas, the dvd disk still is out of sync. Not as bad as it was, but it's still annoyingly evident. I did them one at a time with avi_gain, then converted with FAVC. Watching them on windows media player, both before and after avi_gain, they were in sync. It's something in the conversion, but I have no idea what to try next. The first post I made was converting avi to dvd, and a guy there said that convertXto DVD synced pretty well, but not perfectly. Should I try that, or is there some other program or way to svnc the audio. Any and all responses are appreciated. Thanks.
  audio sync problem, how to work out progressive audio sync delayBy jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09
  MKVvextract stretches extracted audio/Audio not in sync with videoBy cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15
  How to sync the dubbed audio to make a dual audio .aviBy Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17
  An app to visually sync audio to video similar to Subtitle Edit visual syncBy cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54
  SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvidBy dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
