am planning to build an HD HTPC which will also be used for gaming purpose
i download HD rips from torrent sites , so i guess i dont have to worry about HDCP issues since all of those HD dvd/ bluray rips will have the HDCP compliant checks removed (and encodes dont have it )..
so can i build a cheaper hd HTPC since i dont need to worry about HDCP certified hardware
ps: blurays/hd-dvd isnt available in my place and wont be available for some time , that is why am downloading it , otherwise i would have payed for it
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
HDCP
By Baldrick in forum GlossaryReplies: 7Last Post: 4th Apr 2023, 11:34 -
HDCP on a HTPC does not work.
By _punished_soul in forum DVD & Blu-ray WritersReplies: 3Last Post: 20th Dec 2009, 10:55 -
HDCP troubles...
By AKA510 in forum Blu-ray RippingReplies: 7Last Post: 27th Nov 2009, 08:12 -
WD TV is HDCP compliant?
By Supremo316 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Nov 2009, 19:29 -
HDCP the way forward.
By NICEBUD in forum Newbie / General discussionsReplies: 5Last Post: 23rd Sep 2008, 16:36
