I just updated from 0.0.9x to 0.0.9y, and now every time I press Encode, it asks me to locate the application 'Progress'. Since it's part of the ffmpegX package, I can't find it using that locator window. I try pulling it out of the package and into Applications. Now it finds it, but doesn't work!!
What's going on??? Now I'm having more problems than I ever had!!! Maybe I should've stuck with 0.0.9x?? Should I reinstall that version???
"Damaged people are dangerous, they know they can survive."
The issue has been reported before (with a solution reply):
https://forum.videohelp.com/topic344989.html#1805609
You should put it back.Originally Posted by BeatriceBlue
K, deleted the alias and then emptied the Trash. Now it's still finding it in the package fine since the alias pointed it in the right place. Seems I took the long way around to do the same basic thing as they described.
Sorry for bringing it up again. I don't know why that previous topic didn't come up in my search!!"Damaged people are dangerous, they know they can survive."
In case other people would also encounter this problem : select the main ffmpegX application in the list when asked to locate ffmpegXprogress.app. That should fix the problem.
Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
video loses subtitles when it gets hot
By flannob in forum Newbie / General discussionsReplies: 3Last Post: 14th Sep 2011, 13:15 -
isohunt loses big
By deadrats in forum Off topicReplies: 1Last Post: 29th Dec 2009, 09:21 -
ffmpegx, avi loses sound...
By tomyknoker in forum ffmpegX general discussionReplies: 3Last Post: 17th Sep 2008, 14:29 -
subs loses quality after encoding
By evile1690 in forum SubtitleReplies: 11Last Post: 2nd Sep 2008, 09:17 -
conversion loses color
By ranchhand in forum Video ConversionReplies: 13Last Post: 14th Aug 2008, 23:46
