Using ffmepx to try to encode a blu-ray disc that was converted to an .avi file with 5.1 audio, and include a .srt file, so I can burn to DVD using Toast. Having a hard time. Also tried with another .mkv file, also wanted to include subs. Got basically the same error with both:
.AVI File:.MKV File:Code:Encoding started on Tue Feb 26 19:00:25 PST 2008 /bin/sh: line 1: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler movtoy4m Copyright 2002-2006 Johan Lindström All rights reserved.. ERROR: Could not open movie: /Users/beatriceblue/Movies/Control/Control (2007) LiMiTED DVD Rip DoNE CD1.avi **ERROR: [yuvscaler] Could'nt read YUV4MPEG header!Using ffmpegx version 0.0.9x r2. Video plays fine in mplayer when Preview is clicked. Tried using VisualHub, but no subtitle settings available in that program. Going to download ffmpegx 0.0.9y now and see if that changes it.Code:Encoding started on Tue Feb 26 19:54:23 PST 2008 /bin/sh: line 1: /Library/Application Support/ffmpegX/mpeg2enc: Malformed Mach-o file INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler movtoy4m Copyright 2002-2006 Johan Lindström All rights reserved.. ERROR: Could not open movie: /Users/beatriceblue/Movies/untitled folder/No Country For Old Men 2007 720p.mkv **ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
Can someone help? I used to be able to do this fine with ffmpegx, but haven't tried in a long time. Either help me fix ffmpegx or suggest an alternative??? Normally want to preserve audio and add subtitle option.
You are in breach of the forum rules and are being issued with a formal warning. 'Control' and 'No Country for Old Men' have not been released to DVD.
/ Moderator redwudz
"Damaged people are dangerous, they know they can survive."
This error says your mpeg2enc file is no good (malformed). Try downloading and installing that binary again.Originally Posted by BeatriceBlue
Thanks, Case, but now other than my Progress problem which I've explained https://forum.videohelp.com/topic346892.html, now I get the following error:
What now?? Please help me fix it!!Code:INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames Tue Feb 26 22:55:31 PST 2008 INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler movtoy4m Copyright 2002-2006 Johan Lindström All rights reserved.. INFO: [mpeg2enc] SETTING EXTENDED MMX for MOTION! INFO: [mpeg2enc] SETTING SSE and MMX for TRANSFORM! INFO: [mpeg2enc] SETTING EXTENDED MMX for PREDICTION! ERROR: Could not open movie: /Users/beatriceblue/Movies/Control/Control CD1.avi **ERROR: [yuvscaler] Could'nt read YUV4MPEG header! **ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
Get this for the .mkv file:
Code:INFO: [yuvscaler] yuvscaler 1.9.0 (15-02-2004) is a general scaling utility for yuv frames INFO: [yuvscaler] (C) 2001-2004 Xavier Biquard <xbiquard@free.fr>, yuvscaler -h for help, or man yuvscaler Tue Feb 26 23:19:46 PST 2008 movtoy4m Copyright 2002-2006 Johan Lindström All rights reserved.. INFO: [mpeg2enc] SETTING EXTENDED MMX for MOTION! INFO: [mpeg2enc] SETTING SSE and MMX for TRANSFORM! INFO: [mpeg2enc] SETTING EXTENDED MMX for PREDICTION! ERROR: Could not open movie: /Users/beatriceblue/Movies/untitled folder/No Country For Old Men 2007 720p.mkv **ERROR: [yuvscaler] Could'nt read YUV4MPEG header! **ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
Ran upstairs, updated the mpeg2enc.intel on my MacBook (which is still running v0.0.9x), and now it seems to be working just fine!! Weird!
Guess I get to go reinstall the older version on the iMac unless someone knows what's going on with it!
Thanks a million, Case!!"Damaged people are dangerous, they know they can survive."
The DVD mpeg2enc preset defaults to "Decode with Quicktime". This only works if QuickTime can in fact decode the source file. A default QuickTime installation may not be able to decode every advanced scheme used for XviD video.
So, my guess is that there is a difference in 3rd party components for QuickTime on these machines. Maybe one has DivX/XviD/3ivX/Perian installed and the other not?
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
Multiple SUBs on AVI file?
By poumtatalia in forum SubtitleReplies: 1Last Post: 6th May 2010, 04:15 -
Adding subs to a .avi file
By stgdlf in forum Newbie / General discussionsReplies: 7Last Post: 21st Nov 2009, 01:34 -
How to burn avi with subs onto a CD?
By Meagain in forum Newbie / General discussionsReplies: 2Last Post: 10th Apr 2009, 18:40 -
Author and Burn AVI file with subs
By Squid_uk in forum Newbie / General discussionsReplies: 4Last Post: 14th Oct 2007, 07:12
