i'd like to convert the tv shows episodes (350 MB) and burn-in the brazilian subs i make cos my dvd player's font is small, white and with no border... the ones i make in the pc are yellow, with border and big
i'd like to convert the source file and generate one with the same quality (keepin the same size)
i used to be able to do that in my old pc but i got a new one (MUUUUUCH faster), but even with the same config, it doesn't work anymore
i used all that "XviD calc" thing to generate the "target bitrate" but now it's useless
seriously, any help is MUCH appreciated... i'm gettin tired of trying
Can't be done. You will lose some quality if you try to keep to the same size.i'd like to convert the source file and generate one with the same quality (keepin the same size)
Vcalc (Videocalc) can do your bitrate calculations for you (actually, any decent bitrate calculator can).
That said, you can use g-spot or mediainfo to tell you waht bitrate the original used, and use that - if you want the same file size.
AutoGK will take all the guess work out of itRead my blog here.
i've tried many times to set the same bitrate of the input file but it always generates a smaller output file
AutoGK is great, but it just doesn't work properly with the vbr audio that ALL the tv shows have... that's its only problem. it'd be so great if it could recognize the vbr audio fine -
To paraphrase and old fabric salesman, "Never mind the filesize, feel the quality"
If the quality is what you need, does it matter if it is slightly smaller ?
Otherwise, you might post some screenshots of how you set up the encoder. Someone might see something there that will help.Read my blog here.
If you are happy with the way you've been doing this (and are certain that it's VBR causing the problem, not something else) one option is to demux the audio, re-encode with CBR, remux audio & video.
What software are you using to author the DVD? convertxtodvd gives subtitle options like font size, colors, placement etc... but I'm not sure if your standalone player would support this. -
i wanna convert the '.avi' files of the tv shows i download from torrentsOriginally Posted by poisondeathray
i wish there could be an easier way than demux/mux/convert/burn-in... all these damn lotta things
i still have faith in AutoGK... i'd like to know how it configures the xvid encoder to generate a file with that exact size
AutoGK - XviD to XviD to reduce file size
By marioval in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 15:37 -
How to control font size and position in Subtitle Workshop
By pchan in forum SubtitleReplies: 2Last Post: 19th Jan 2010, 08:08 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 22:05 -
Stand-alone video resizer/re-encoder with file-size control?
By Brains in forum Video ConversionReplies: 7Last Post: 9th May 2008, 07:30 -
Flv encoder that gives precise control over A/V parameters?
By brassplyer in forum Video Streaming DownloadingReplies: 4Last Post: 3rd May 2008, 22:39
