Hello...
I'm posting this here as there does not seem to be a place dedicated to CODEC problems.
I'm looking for a CODEC that will play MP4 and M4V files in Windows Media Center. The files I have will play in VLC (so I know they are good) but I have been unable to find a CODEC that can play them.
I'm pretty sure that Windows Media Center uses the Windows Media Player for rendering video so a CODEC that's compatible with WMP should work in Windows Media Center.
Thanks, in advance, to any one who can help.
Baldrick: Before posting this article I reviewed your earlier post on using ffdshow and the haali media splitter. As I'm sure you know, there's not much documentation on these two programs and I was unable to get them to work.
I'm willing to try again, if I can find even the smallest shread of documentation to help. -
I found a pretty easy way to do this using only free tools.
1) Download GSpot. It doesn't need to be installed to run.
2) Drag any file that won't play in Media Center and drop it on GSpot.
3) When GSpot opens, note the audio and video codes displayed.
4) Download the K-Lite CODEC Pack and double click it to begin the install.
5) On the CODEC selection screen, begin by pulling down on the menu and choosing "Unselect All". This step is very important otherwise you will get a ton of stuff on your system you don't want.
6) Check just the CODECS you need from step 3) above.
7) Finish the K-Lite installation.
The K-Lite CODEC Pack knows how to install ffdshow and the haali media spliter automatically. If you make a mistake, repeat steps 5) through 7). The K-Lite CODEC Pack remembers your previous selections to make it easy to make modifications to the install.
Some people believe that the K-Lite CODEC Pack contains stuff that is either copyrighted or not good for your system. Be sure to select only the CODECS you need.
m4v to MP4 ??
By The.King in forum Video ConversionReplies: 15Last Post: 5th May 2015, 13:48 -
Add Soft Subtitles and Chapters to m4v / mp4 (How to in Windows)
By mikec798 in forum SubtitleReplies: 5Last Post: 2nd Nov 2012, 12:49 -
M4V to MP4 Container help
By Cornholio77 in forum Video ConversionReplies: 5Last Post: 1st Jan 2012, 04:28 -
m4v > avi or mp4
By empershand in forum ffmpegX general discussionReplies: 2Last Post: 17th Mar 2008, 16:55 -
How Do I Convert M4V to MP4
By streetracer096 in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2007, 05:17
