I want to build a pc for the primary purpose of editing video. This will not, strictly speaking, be a home theater pc, because I have no intention of connecting it to a tv. I plan to use it to transcode non-copyrighted mpeg2 source material into Divx, Xvid, h.264 or MKV with no loss in resolution. Most of the source material will be 720x480. My goal will be to preserve multiple audio tracks and subtitle sets where the exist.
Is there any point in spending money for a dual-core or quad-core cpu?
I understand that multiple cores make apps run faster, but only if you're using an app which is written to take advantage of hyperthreading and multi-core processors. If not, then one core runs like crazy, but the others are essentially idle (or so I understand).
I want to buy all the cpu and memory I need to do this task quickly, but I don't wish to over-spend on hardware which doesn't really improve performance. Any suggestions?
If it helps you any, I am getting by just fine with a 3 GHz. A 30 minute program takes about 2 - 2.5 hrs to encode using 2-pass VBR in TmpgEnc, a notoriously slow (but great quality) encoder. Funny, but it seems an hour-long program doesn't seem to take that much longer.
Darryl -
Originally Posted by GrayStrickland
ntscuser:
What are the specs of your pc and how long, roughly, does it take you to transcode 1 hour of source material? -
Building a nice video editing machine- suggestion????
By ingeborgdot in forum ComputerReplies: 2Last Post: 3rd Jan 2011, 10:08 -
Building a PC for Video Editing/Encoding - Need Advice plz!
By MaTTuP in forum ComputerReplies: 9Last Post: 6th Nov 2010, 10:37 -
Help: Building Computer for HD Video Editing
By Rantlers in forum ComputerReplies: 25Last Post: 2nd Apr 2010, 10:52 -
need help: topic - video/audio capturing editing software
By Uebermensch1984 in forum EditingReplies: 2Last Post: 29th Dec 2008, 23:49 -
slightly off topic - added router - 2 machines dodgey upload rates
By BattyRoy in forum MacReplies: 5Last Post: 11th Jan 2008, 23:40
