Hi I have this problem my windows media player 11 wont let me play avi files anymore and it is weird, It only really started like a month ago from what I have noticed and have had the computer for nearly a year and had wmp 11 installed ever since i got it. I used to play them fine on it but now I can't it's weird I can however get them to play on VLC and realplayer and sometimes itunes (I never have had much success playing video on itunes anyway).
this is all the info that microsoft webhelp gave me:
Windows Media Player Error Message Help
You've encountered error message C00D11B1 while using Windows Media Player. The following information might help you troubleshoot the issue.
Cannot play the file
Windows Media Player cannot play the file. You might encounter this error message for one of the following reasons:
Your sound device, such as a sound card or sound controller, requires an updated driver. To determine if an updated driver is available, see Windows Update at the Microsoft Web site, or see the sound device manufacturer's Web site.
Your sound device is not functioning properly. Try using Device Manager to check the status of your sound device.
To check the status of your sound device
1.
Do one of the following:
o
If you are running Windows XP, click Start, right-click My Computer, and then click Manage.
o
If you are running Windows Vista, click Start, right-click Computer, and then click Manage.
2.
In the pane on the left, click Device Manager.
3.
In the pane on the right, expand Sound, video and game controllers, and then look for the name of your sound device.
4.
o
If your sound device is listed but the icon includes a red "X," the device has been disabled. To enable the device, right-click the icon, and then click Enable.
o
If your sound device is not listed, in the pane on the right, expand Other devices. If Multimedia Audio Controller appears in the list, right-click the icon, and then click Update Driver or Update Driver Software. Follow the on-screen instructions to find and install the driver software.
If you are not able to find and install the correct driver software, see your computer manufacturer's or sound device manufacturer's Web site for further assistance.
You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again. For details, see your computer manufacturer's or sound device manufacturer's Web site.
You are trying to play a file on the Internet and the server might be temporarily unavailable or there might be a network issue. Try again later.
You are trying to play an MP3 file that contains compressed ID3 headers. The ID3 header is a portion of the file that stores the song's album information (for example, the song name, artist name, album name, and genre). This information is sometimes called a "tag."
To fix the problem, make a copy of the file and then use a non-Microsoft ID3 tag editing program to remove or reset the file's ID3 headers. After you remove the ID3 headers, Windows Media Player should be able to play the MP3 file.
Attempting to remove ID3 headers might damage the file and make it unplayable. Therefore, always make a copy of the file before you edit it.
If this solution does not resolve the problem, the file might be corrupted.
Now I know that these files aren't corrupt because they used to work. This problem coincides with another problem I have and that is when ever I open a new window of anything my computer beeps once. Before you say about sound driver problem that doesn't explain why I can still listen to music and such and why only avi files dont work on WMP11.
I also notice that these problems coincide with the high temperatures we have been experiencing over the past 2 months.
If anyone knows how to fix this please let me know.
P.S. I am sorry if i didn't post this in the right place
You may want to try reregistering quartz.dll again after the Filmerit cleanup.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
AVI file from Nikon camera won't play in WMP.
By frankmaster100 in forum Newbie / General discussionsReplies: 6Last Post: 27th Dec 2010, 20:02 -
How to play avi/H264 video file on WMP 12
By Tatl in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2010, 18:02 -
WMP 10 won't play avi with subtitle file.
By zlmdlo in forum Software PlayingReplies: 1Last Post: 14th Dec 2009, 04:22 -
What do you use when WMP unable to play *.WMV, *.AVI.
By pwangdel in forum RestorationReplies: 2Last Post: 5th Mar 2008, 20:52
