I have a BIN/CUE file set from which I burned an SVCD. Unfortunately my Panasonic DMR-E20 is only able to do this jerky 1sec play... 1sec pause... 1sec play kind of thing. Without the original MPG I am unable to try to run conversions to get something that my Panasonic will like.
Is there anything that will rip the SVCD I burned and give me the an MPG to work with?
Thanks!
just copy the contents of /mpeg2(mpegav) to your hdd and demultiplex(bbtools, tmpgenc etc...) then re-encode
The file in \MPEG2 won't copy. I guess that isn't surprising since its directory entry says it is an 818M file residing on CD-R media that can only hold 700M.
Even if it did, I don't see how demuxing and remuxing would do anything positive. -
is that x1024 or x1000 mb? if the latter the disc is overburned which might cause problems copying. if you still have the .cue/.bin try isobuster to extract the .mpg. i said nothing about remuxing
:lol:
Hi everyone!!I am totally new in this field and I would like to ask for help from anyone who can help me out. Firstly I want to know how to copy a DVD movie onto my cdwriter(vcd/svcd) and secondly i have just bought Ulead videostudio5,dvd version,with dvd plug-in. Can this software be of any help to rip dvds on cdr? I know most of you will be laughing at me because i am e newbie in this field, i don't mind, but please help me.Thanks. :(
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Ripping Karaoke DVD to VCD (.DAT) (Mpeg1)
By Nhuii in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 21st Aug 2010, 00:01 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
