Working on a VHS->DVD conversion.
I am using AviSynth->CCE Basic to output mpv and mpa files. I wanted to then import these files into NeroVision for authoring but whenever I import the mpv file only the first half of the video is imported. The full audio (mpa) file is imported however. It is very strange. I am guessing it has something to do with the mpeg flags that CCE is using.
Has anyone experienced this before?
	No. CCE produces DVD compliant mpeg files. Either you aren't converting the whole thing, or Nero is wrong. My money is on Nero being the problem.
 Are you actually scanning the whole video to make sure it's incomplete, or taking Nero's word for it based on timecodes/running time as displayed by Nero. I would scan the file, as Nero may be reading the headers in correctly and showing a truncated running time.Read my blog here.
	The mpv file plays correctly in VLC (50 seconds), but once imported into NeroVision it claims it is only 22 seconds. Additionally, when I play the preview in NeroVision the video stops at 22 seconds but the audio (mpa) keeps going for the full 50 seconds.
 Ugh, I just need NeroVision for authoring. I don't need fancy menus but I also don't want to spend any more money.
	Oh yeah, one other thing... If I encode in CCE @ CBR with a system stream (single mpg file) the file imports into NeroVision correctly (full 50 seconds).
	GUIForDVDAuthor or DVD Styler are both free and can author and do menus. Much more reliable than Nero. Read my blog here.
	From the rash of posts I've seen lately, almost anything is more reliable than Nero.
 I have personally used GUIForDVDAuthor. It's really very good, especially if you're a beginner. There are lots of tutorials and guides around and the author is a pretty frequent poster on these boards.
 Give it a shot. It might not have a spashy a GUI as Nero, but I'll take functionality over "splashy" any day.
	Are you importing that script manually in CCE ?
 Can you show your Avisynth script ?
 One test you can make :
 add Info() to the end of your script and play it in WMP....see the framecount
 then when you convert with CCE see if it is encoding the same framecount
 that seems to me a DS script with ConvertFPS set to true, which makes that symptoms, but is just a thought
  Pinnacle Studio14 HD>AVI Files from Canon G6 cannot be Imported into STUDIOBy rivrbyte in forum Capturing and VCRReplies: 2Last Post: 11th Sep 2011, 15:13
  How does one process mpa and mpv files?By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 14:30
  With Nero 7 Ultra, why are imported dvd files so big?By wisny in forum EditingReplies: 13Last Post: 13th Mar 2011, 08:38
  can't play .mpv files with soundBy gbabione in forum Video ConversionReplies: 10Last Post: 23rd Nov 2008, 12:10
  Sony Vegas 7 doesn't let *.mov & *.avi files be imported into project..By koldun in forum EditingReplies: 5Last Post: 1st Jul 2008, 16:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
