Results 1 to 11 of 11
    Feb 2008
    I have a ~20 second MOV that I'd like to cut the first few seconds off the beginning and the end, I've looked for about an hour for freeware that would allow me to do this but haven't found anything. Anyone have any suggestions? Thanks.
  2. You try MPEG Streamclip?
    This editor use and require installed QuickTime (or QuickTime Alternative).
    Can open MOV file, edit (example remove fragment) and save without recompression (Save As... option).
    Feb 2008
    Thank you so much, that software is awesome
    Feb 2008
    thank you for the video editing software.
  5. I used mepg streamclip to trim but after I couldn't determine how to save the new video.
    Please help!
  6. I down loaded the 'FREE' MPEG Streamclip and used it to trim a video. But guess what, it is not free! You have to buy it to work prpperly!!
  7. But it is free? And Quicktime Alernative (1.81) is free as well?
  8. When I used it. The message came back stating that only one third of the video was trimmed and to get the entire video trimmed I would have purchase it .
  9. Has any body used 'FREE VIDEO CUTTER' TO TRIM .mov video files?
    Aug 2006
    I agree with videobruger. I went to the developer's (Squared 5) website. According to them, MPEG Streamclip is still free. Quicktime Alternative 1.81 is free too.
    That being said the existing MPEG Streamclip and Quicktime Alternative 1.81 stopped working for me years ago using Windows 7. The Windows version probably needs updating. The most recent Beta came out in 2012.
    Apple's Quicktime Pro is payware, but you only need that if you choose to use Apple's Quicktime 7 for Windows instead of Quicktime Alternative 1.81.
    Not me. In case you didn't notice, Free Video Cutter is bundled with links to other websites and third-party apps installations including toolbars. Install carefully if you do not want them.
