I'm using the Demo version of SVCD2DVD v2.5. The completed DVDs have no audio.
System-Win XP Pro, less than a month old (plenty of space, memory, processing speed);
VCDs were opened with VCDEasy. The mpegs have audio-44000 Hrz;
The DVDs created appear to do everything right except...they are silent;
I'm using Verbatim DVDs.
Am I missing a setting somewhere to generate 48000 Hrz audio?
I really would like to get this software to work and get the full version. I have several Chinese tv series that are available only on VCD (one has over 60 VCDs...) and I would like to combine episodes into something less unwieldy.
Please help. Thank you.
				Results 1 to 9 of 9
	Can you post the log file so i can see what is going on? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	The only difference is that I am now using the registered version, with the same silent result.Originally Posted by ChrissyBoy
 Good luck, and thanks.
 here's the log:
 ************************ SYSTEM INFORMATION ************************
 ***************************** SVCD2DVD *****************************
 Title: 2.5
 Version: 2.5.3600.0
 Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
 Executable size: 2.57 MB
 Executable size in bytes: 2703443
 Executable CreationTime: 12/9/2007 10:41:26 PM
 Executable LastWriteTime: 2/26/2008 2:44:10 PM
 Executable LastAccessTime: 2/27/2008 3:20:25 PM
 ************************* Operating System *************************
 Operating System: Microsoft Windows XP Professional
 Service Pack: Service Pack 2
 Version : 5.1.2600
 Windows Directory : C:\WINDOWS
 OSLanguage: 1033
 CodeSet: 1252
 CountryCode: 1
 Local: 0409
 Total Physical Memory: 1.98 GB
 Free Physical Memory: 1.39 GB
 Total Virtual Memory: 1.99 GB
 Free Virtual Memory: 1.95 GB
 ***************************** Computer *****************************
 Computer Manufacturer Name: INTEL_
 Computer Model: DP35DP__
 System Type: X86-based PC
 Computer Name: OWNER-84A1E9810
 DomainRole: x2c3419cdc9b8e007
 Number Of Processors: 4
 User Name: OWNER-84A1E9810\Owner
 ***************************** Processor ****************************
 Manufacturer: GenuineIntel
 Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
 Description: x86 Family 6 Model 15 Stepping 11
 CPU Speed: 2.4GHz
 CPU FSB: 266MHz
 L2 Cache Size: 4.00 KB
 CPU Speed: 2.4GHz
 CPU FSB: 266MHz
 CPU Speed: 2.4GHz
 CPU FSB: 266MHz
 CPU Speed: 2.4GHz
 CPU FSB: 266MHz
 10:25:17: Logical CPUs: 4
 ***************************** Time Zone ****************************
 Time Zone: (GMT-05:00) Eastern Time (US & Canada)
 ****************************** VIDEO *******************************
 Name: NVIDIA GeForce 8500 GT
 Processor: GeForce 8500 GT
 Mode: 1680 x 1050 x 4294967296 colors
 Video Ram: 512 MB
 Status: OK
 ****************************** Drives *******************************
 DeviceID: C:
 FileSystem: NTFS
 FreeSpace: 131 GB
 DeviceID: E:
 FileSystem: NTFS
 FreeSpace: 289 GB
 DeviceID: G:
 FileSystem: NTFS
 FreeSpace: 69.6 GB
 ********************* END OF SYSTEM INFORMATION ********************
 ************************* ProjectMetaData **************************
 <?xml version="1.0" encoding="utf-8"?>
 <SVCD2DVD DateTime="2/27/2008 10:25:17 AM" Filename="NONE">
 <AssetSet>
 <Asset ID="4c7b6b30-6f86-4d13-bf44-eb9d047fd5e6" Path="C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS" Filename="WolfKnight1.mpg" />
 <Asset ID="1bc6fd2e-350c-4059-8d39-754c0ac8459c" Path="C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS" Filename="wolfknight2.mpg" />
 <Asset ID="36fbd156-030d-431e-bbf2-fe53e1d543d1" Path="C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS" Filename="WolfKnight3.mpg" />
 </AssetSet>
 <DVDStructure>
 <TitleSet Name="Episode 1" PostCmd="" MenuButtonType="0">
 <MenuButton X1="87" Y1="135" X2="284" Y2="201" FontFamily="Papyrus" FontSize="27.75" FontStyle="1">Episode 1</MenuButton>
 <Title Name="WolfKnight1.mpg" AssetID="4c7b6b30-6f86-4d13-bf44-eb9d047fd5e6" MplexOffset="0" />
 </TitleSet>
 <TitleSet Name="Episode 2" PostCmd="" MenuButtonType="0">
 <MenuButton X1="265" Y1="243" X2="462" Y2="309" FontFamily="Papyrus" FontSize="27.75" FontStyle="1">Episode 2</MenuButton>
 <Title Name="wolfknight2.mpg" AssetID="1bc6fd2e-350c-4059-8d39-754c0ac8459c" MplexOffset="0" />
 </TitleSet>
 <TitleSet Name="Episode 3" PostCmd="" MenuButtonType="0">
 <MenuButton X1="448" Y1="354" X2="645" Y2="420" FontFamily="Papyrus" FontSize="27.75" FontStyle="1">Episode 3</MenuButton>
 <Title Name="WolfKnight3.mpg" AssetID="36fbd156-030d-431e-bbf2-fe53e1d543d1" MplexOffset="0" />
 </TitleSet>
 <DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="True" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Documents and Settings\Owner\My Documents\My Pictures\AVSEQ01_0001.bmp" AudioPath="">
 <PlayAllButton X1="494" Y1="135" X2="645" Y2="201" FontFamily="Papyrus" FontSize="27.75" FontStyle="1">Play All</PlayAllButton>
 </DVDMenu>
 </DVDStructure>
 <Settings>
 <General InitialAssetFolder="C:\Documents and Settings\Owner\My Documents\WolfKnight\New Folder" InitialDVDFolder="C:\Documents and Settings\Owner\My Documents\WolfKnight\dvdinitialoutput" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="C:\Documents and Settings\Owner\My Documents\WolfKnight\dvdprojectfolder" InitialMenuBackgroundFolder="C:\Documents and Settings\Owner\My Documents\WolfKnight\menufolder" DeleteS2DFiles="False" UseDVDShrink="False" />
 <Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="C:\Documents and Settings\Owner\My Documents\My Pictures\AVSEQ01_0001.bmp" TVStandard="PAL" FontFamily="Papyrus" FontSize="27.75" FontStyle="1" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
 <Process AudioEncoding="ac3" Chapters="Every 0 mins (none)" SkipMPA48="True" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
 <Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
 <Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
 </Settings>
 </SVCD2DVD>
 Processing assets for DVD creation
 =================== AV Details ===================
 File Size: 462 MB
 file=C:\\Documents and Settings\\Owner\\My Documents\\WolfKnightMPEGS\\WolfKnight1.mpg
 FormatName=mpeg
 Num_Frames=69485
 DurationInSecs=2779
 Duration=00:46:19.4
 VideoCodec=mpeg1video
 VideoFFSTNum=0
 Width=352
 Height=288
 Standard=PAL
 BitRate=1395
 AudioStreamCount=1
 Audio1FFSTNum=1
 Audio1StreamID=[0x1c0]
 Audio1SampleRate=44100
 Audio1Codec=mp2
 Audio1BitRate=224
 Audio1Channels=2
 Processing WolfKnight1.mpg
 10:25:17: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
 10:25:17: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
 10:25:17: libavutil version: 49.1.0
 10:25:17: libavcodec version: 51.27.0
 10:25:17: libavformat version: 51.12.1
 10:25:17: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
 10:25:17: Input #0, mpeg, from 'C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\WolfKnight1.mpg':
 10:25:17: Duration: 00:46:19.4, start: 0.232644, bitrate: 1395 kb/s
 10:25:17: Stream #0.0[0x1e0]: Video: mpeg1video, yuv420p, 352x288, 1120 kb/s, 25.00 fps(r)
 10:25:17: Output #0, dvd, to 'C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\WolfKnight1_S2D.mpg':
 10:25:17: Stream #0.0: Video: mpeg1video, yuv420p, 352x288, q=2-31, 1120 kb/s, 25.00 fps(c)
 10:25:17: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
 10:25:17: Stream mapping:
 10:25:17: Stream #0.0 -> #0.0
 10:25:17: Stream #0.1 -> #0.1
 10:25:17: Press [q] to stop encoding
 10:25:17: [dvd @ 0084E46C]buffer underflow
 10:27:05: video:380197kB audio:152063kB global headers:0kB muxing overhead 4.750453%
 File Size: 467 MB
 file=C:\\Documents and Settings\\Owner\\My Documents\\WolfKnightMPEGS\\wolfknight2.mpg
 FormatName=mpeg
 Num_Frames=70235
 DurationInSecs=2809
 Duration=00:46:49.4
 VideoFFSTNum=0
 Width=352
 Height=288
 Standard=PAL
 BitRate=1395
 AudioStreamCount=1
 Audio1FFSTNum=1
 Audio1Codec=mp2
 Audio1BitRate=224
 Audio1Channels=2
 Processing wolfknight2.mpg
 10:27:06: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
 10:27:06: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
 10:27:06: libavutil version: 49.1.0
 10:27:06: libavcodec version: 51.27.0
 10:27:06: libavformat version: 51.12.1
 10:27:06: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
 10:27:06: Input #0, mpeg, from 'C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\wolfknight2.mpg':
 10:27:06: Duration: 00:46:49.4, start: 0.232633, bitrate: 1395 kb/s
 10:27:06: Stream #0.0[0x1e0]: Video: mpeg1video, yuv420p, 352x288, 1120 kb/s, 25.00 fps(r)
 10:27:06: Output #0, dvd, to 'C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\wolfknight2_S2D.mpg':
 10:27:06: Stream #0.0: Video: mpeg1video, yuv420p, 352x288, q=2-31, 1120 kb/s, 25.00 fps(c)
 10:27:06: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
 10:27:06: Stream mapping:
 10:27:06: Stream #0.0 -> #0.0
 10:27:06: Stream #0.1 -> #0.1
 10:27:06: Press [q] to stop encoding
 10:28:51: video:384297kB audio:153710kB global headers:0kB muxing overhead 2.422834%
 File Size: 453 MB
 file=C:\\Documents and Settings\\Owner\\My Documents\\WolfKnightMPEGS\\WolfKnight3.mpg
 FormatName=mpeg
 Num_Frames=68136
 DurationInSecs=2725
 Duration=00:45:25.4
 VideoFFSTNum=0
 Width=352
 Height=288
 Standard=PAL
 BitRate=1395
 AudioStreamCount=1
 Audio1FFSTNum=1
 Audio1Codec=mp2
 Audio1BitRate=224
 Audio1Channels=2
 Processing WolfKnight3.mpg
 10:28:52: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
 10:28:52: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
 10:28:52: libavutil version: 49.1.0
 10:28:52: libavcodec version: 51.27.0
 10:28:52: libavformat version: 51.12.1
 10:28:52: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
 10:28:52: Input #0, mpeg, from 'C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\WolfKnight3.mpg':
 10:28:52: Duration: 00:45:25.4, start: 0.240800, bitrate: 1395 kb/s
 10:28:52: Stream #0.0[0x1e0]: Video: mpeg1video, yuv420p, 352x288, 1120 kb/s, 25.00 fps(r)
 10:28:52: Output #0, dvd, to 'C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\WolfKnight3_S2D.mpg':
 10:28:52: Stream #0.0: Video: mpeg1video, yuv420p, 352x288, q=2-31, 1120 kb/s, 25.00 fps(c)
 10:28:52: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
 10:28:52: Stream mapping:
 10:28:52: Stream #0.0 -> #0.0
 10:28:52: Stream #0.1 -> #0.1
 10:28:52: Press [q] to stop encoding
 10:28:52: [dvd @ 0084E46C]buffer underflow
 10:30:25: video:372842kB audio:149114kB global headers:0kB muxing overhead 4.807656%
 10:30:25: Done: Processing assets for DVD creation
 Authoring DVD Folders
 10:30:25: Creating TitleSet # 1
 10:30:25: SVCD2DVD: DVDfolders
 Generating DVD folders please wait....
 10:30:25: -->: DVDFolders creating VTS
 10:30:25: -->: VTS 01
 10:30:25:
 DVD Folders: Processing C:\Program Files\BadgerIT\SVCD2DVD v2.5\dummymenuPAL.mpg...
 10:30:25:
 DVD Folders: Processing C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\WolfKnight1_S2D.mpg...
 10:30:49:
 10:30:49:
 10:31:03:
 10:31:04: Creating TitleSet # 2
 10:31:04: SVCD2DVD: DVDfolders
 10:31:04: -->: DVDFolders creating VTS
 10:31:04: -->: VTS 02
 10:31:04:
 10:31:04:
 DVD Folders: Processing C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\wolfknight2_S2D.mpg...
 10:31:29:
 10:31:29:
 10:31:34:
 10:31:34: Creating TitleSet # 3
 10:31:34: SVCD2DVD: DVDfolders
 10:31:34: -->: DVDFolders creating VTS
 10:31:34: -->: VTS 03
 10:31:34:
 10:31:34:
 DVD Folders: Processing C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\WolfKnight3_S2D.mpg...
 10:32:00:
 10:32:00:
 10:32:01:
 10:32:01: Finalising DVD...
 10:32:01: Encoding menu...
 ---------------------------- ENCODING MENU ----------------------------
 TV Standard: PAL
 Aspect Ratio: 4:3
 Image size: 768x576
 Resize size: 720x576
 10:32:04: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
 10:32:04: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
 10:32:04: libavutil version: 49.1.0
 10:32:04: libavcodec version: 51.27.0
 10:32:04: libavformat version: 51.12.1
 10:32:04: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
 10:32:04: Input #0, image2, from 'C:\\Documents and Settings\\Owner\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.3600.0\\menu\\background1.jpg':
 10:32:04: Duration: 00:00:00.0, start: 0.000000, bitrate: N/A
 10:32:04: Stream #0.0: Video: mjpeg, yuvj420p, 720x576, 25.00 fps(r)
 10:32:04: Output #0, rawvideo, to 'C:\\Documents and Settings\\Owner\\Local Settings\\Application Data\\Badger I.T.\\SVCD2DVD 2.5\\2.5.3600.0\\menu\\backgroundES.mpv':
 10:32:04: Stream #0.0: Video: mpeg2video, yuv420p, 720x576, q=2-31, 1000 kb/s, 25.00 fps(c)
 10:32:04: Stream mapping:
 10:32:04: Stream #0.0 -> #0.0
 10:32:04: Press [q] to stop encoding
 10:32:04: video:76kB audio:0kB global headers:0kB muxing overhead 0.000000%
 10:32:04: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
 10:32:04: INFO: [???] File C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\backgroundES.mpv looks like an MPEG Video stream.
 10:32:04: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
 10:32:04: INFO: [???] Found 0 audio streams and 1 video streams
 10:32:04: INFO: [???] Selecting dvdauthor DVD output profile
 10:32:04: INFO: [???] Multiplexing video program stream!
 10:32:04: INFO: [???] Scanning for header info: Video stream e0 (C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\backgroundES.mpv)
 10:32:04: INFO: [???] VIDEO STREAM: e0
 10:32:04: INFO: [???] Frame width : 720
 10:32:04: INFO: [???] Frame height : 576
 10:32:04: INFO: [???] Aspect ratio : 4:3 display
 10:32:04: INFO: [???] Picture rate : 25.000 frames/sec
 10:32:04: INFO: [???] Bit rate : 1000000 bits/sec
 10:32:04: INFO: [???] Vbv buffer size : 126976 bytes
 10:32:04: INFO: [???] CSPF : 0
 10:32:04: INFO: [???] SYSTEMS/PROGRAM stream:
 10:32:04: INFO: [???] rough-guess multiplexed stream data rate : 1021744
 10:32:04: INFO: [???] target data-rate specified : 10080000
 10:32:04: INFO: [???] Setting specified specified data rate: 10080000
 10:32:04: INFO: [???] Run-in Sectors = 88 Video delay = 12873 Audio delay = 16473
 10:32:04: INFO: [???] New sequence commences...
 10:32:04: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
 10:32:04: INFO: [???] STREAM e0 completed @ frame 11.
 10:32:04: INFO: [???] Multiplex completion at SCR=3218.
 10:32:04: INFO: [???] Video e0: buf= 42120 frame=000011 sector=00000021
 10:32:04: INFO: [???] VIDEO_STATISTICS: e0
 10:32:04: INFO: [???] Video Stream length: 77827 bytes
 10:32:04: INFO: [???] Sequence headers: 2
 10:32:04: INFO: [???] Sequence ends : 0
 10:32:04: INFO: [???] No. Pictures : 12
 10:32:04: INFO: [???] No. Groups : 2
 10:32:04: INFO: [???] No. I Frames : 2 avg. size 10180 bytes
 10:32:04: INFO: [???] No. P Frames : 11 avg. size 1978 bytes
 10:32:04: INFO: [???] No. B Frames : 0 avg. size 0 bytes
 10:32:04: INFO: [???] Average bit-rate : 1197200 bits/sec
 10:32:04: INFO: [???] Peak bit-rate : 702000 bits/sec
 10:32:04: INFO: [???] BUFFERING stream too short for useful statistics
 10:32:04: INFO: [???] MUX STATUS: no under-runs detected.
 create sub file....done.
 running menu muxer....10:32:18: MUXRATE =4400
 10:32:18: after read_bmp(): xd=720 yd=576 x0=0 y0=0
 10:32:18: Found EOF in .sub file.
 10:32:18: warning, sub on line 0 starts before 4s, (some players won't show it)
 10:32:18: subtitle duration: -1
 10:32:18: ***************** HERE WE GO EVE.ODD *******************
 10:32:18: MenuType: EVEN
 10:32:18: subtitle_packet_size: 3525
 10:32:18: subtitle_packet_size & 1: 1
 10:32:18: subtitle_packet_size mod 2: 1
 10:32:18: MenuType==""
 10:32:18: MenuType=="EVEN"
 10:32:18: WAS ODD
 10:32:18: subtitle_packet_size++
 10:32:18: final subtitle_packet_size: 3526
 10:32:18: max_sub_size=3526
 10:32:18: subtitle inserted at: 0.183033 sd=0
 10:32:18: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.18
 done.
 10:32:18: Encoding menu...Done.
 10:32:18: SVCD2DVD: DVDfolders
 10:32:18: -->: DVDFolders creating table of contents
 10:32:18: scanning C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
 10:32:18: scanning C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_02_0.IFO
 10:32:18: scanning C:\Documents and Settings\Owner\My Documents\WolfKnightMPEGS\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_03_0.IFO
 10:32:18: -->: Creating menu for TOC
 10:32:18:
 DVD Folders: Processing C:\Documents and Settings\Owner\Local Settings\Application Data\Badger I.T.\SVCD2DVD 2.5\2.5.3600.0\menu\menu.mpg...
 10:32:18:
 10:32:18:
 10:32:18: Finalising DVD...Done
 10:32:18: Done: Authoring DVD Folders
 Burning DVD folder
 10:32:18: Burning DVD with ImgBurn...
	No sound when played with PC? Install AC3Filter. Or no sound in DVD standalone? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	Thanks.Originally Posted by ChrissyBoy
 I'm at work now, but I'll try the latest attempt in a standalone player tonight. The earlier disks were just just as silent in standalone players as in the computer. The *.mpg files loaded as assets to make the DVD had no problem with value.
	Well if that still is a problem - can you use the "makesample" tool in the "Tools" folder to create a 5MB sample and email that to me to test please? SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
	Will do when I get home later tonight.Originally Posted by ChrissyBoy
 I like what the video looks like, and I'd really like to get this program to work for me. VCDs are still a popular format for Chinese tv series (I am addicted to costume/swordplay series, and am learning Mandarin the better to follow the stories) and even legitimate releases are sometimes only available as VCDs. I just ordered a 40 VCD series. Being able to convert these to DVDs would make watching them more convenient.
 It is not unusual for Hong Kong VCDs to have 2 audio tracks--one in Cantonese and one in Mandarin. One selects the right or left audio channel when playing them. Is it possible to select one of these for recording onto a DVD? [Not an issue with the present problem--it's from Mainland China, which has mandated the use of Mandarin in movies and tv.]
	Everything is now working fine! I wanted to try the disk on different players and computers before proclaiming success, but everything is working.Originally Posted by ChrissyBoy
 Thank you for your help!
	Cool SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
  Making a multi-track audio CD from a commercial concert DVD ?By MacPCConsultants in forum AudioReplies: 11Last Post: 2nd Jan 2012, 10:26
  Making dvd with audio files onlyBy ian c-nall in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2009, 07:19
  Making an audio CD on NeroBy orfajackson in forum Newbie / General discussionsReplies: 5Last Post: 12th Apr 2009, 17:03
  Making an audio dvd with wav & mp3 filesBy wwervd316 in forum AudioReplies: 1Last Post: 18th Mar 2008, 22:41
  Need advice on making dvd copies and making ISO files please.Thanks!By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
