  1. Hi
    I'm having great difficulty in converting a .h264 file to AVI. I've already tried Super (didn't work) and AVCTOAVI can't seem to run on my computer. Is there any other software that can do this besides the 2 that I mentioned?
    Thanks!
  2. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Is avc2avi giving you an error? Are you trying to double click the avc2avi.exe? It is a command line program that must be run from the command prompt.
    Open a command prompt.
    type this
    C:\ Path to\avc2avi.exe -i C:\Path to\input.h264 -f 23.976 -o C:\Path to\output.avi.
    edit- added option to set output fps. Change 23.976 to whatever fps your source h264 file is. Without this option the default settings will output a 25fps avi.
    Donadagohvi (Cherokee for "Until we meet again")
    Dec 2004
    Triptonia
    why not?
    also avc2avi and super do completely different things.
    and is it an elementary stream you are working with?
    perhaps you should be more specific about your goal,
    as well as more specific about how the methods you've used failed.
    other than that,
    if the plan is to recode,
    using avisynth with directshowsource(), [or AVCsource() with DGAVCDecode if it's elementary]
    and pretty much any encoder you please,
    is the way to go.
    tripp
    Dec 2004
    Triptonia
    there is a gui available
  5. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Really. I didn't know that. Good info to know. What is it?
    I wrote my own simple little gui just for my own personal use but I never released it.
  6. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    Thanks tripp. I will check that out next time I'm booted into windows. Running ubuntu right now.
    Feb 2004
    Australia
    Would be nice to know what container it may be using > gspot helps
    Avidemux > open file
    Warning = use safe mode or it'll come out like crap
    Audio > copy
    Calc > check bitrate for file size required
    Video > compressor > xvid > enter for single pass bitrate > enter number from calc
    Save as new file > name.avi (must add the file extension)
    Wait till completed
    Note: You can also use this method to sample, prior to running the entire file process
