Results 1 to 10 of 10
    Jul 2002
    We've got Vista32 on an ide harddrive and we would like to transfer it to raid 1 using two serial harddrives. The serial drives are connected to a Promise pci plugin card.
    What steps should we take to accomplish this.
    Oct 2005
    666th portal
    don't. leave the os on the single drive to boot from and use the raid 1 for data. raid 1 is a single drive mirrored, just a way to backup data. it's not until you use raid 3, 5, or 6 you get fault tolerance for a failing drive.
    Jul 2002
    To aedipuss:
    Thanks for your reply. Our situation requires that the OS, programs, and data be connected up as raid 1.
    Apr 2004
    Miskatonic U
    The you have to reinstall from scratch or, perhaps, look at one of the imaging tools such as Acronis TrueImage.
    However you cannot just copy Vista and the applications across to a new drive and expect it to work.
    Read my blog here.
    Jul 2002
    To gunslinger:
    If I use the cloning feature in Acronis would the copy then work?
    Jun 2006
    Planet Earth
    You can also try ghost2003 (latest version work with SATA).
    Oct 2005
    666th portal
    just a friendly warning. if you create a raid 1 array and use it as the boot device, if one of the drives fails you will probably not be able to boot the computer. it is not a failsafe array.
    Jul 2002
    True. But if you rebuild the array it will then boot ok.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    ok. just make sure to have a couple spare drives on hand
    try imaging the drives onto the array and then changing the boot drive in the motherboard bios to the array, that's if it supports booting from a pci plugin card of course......
  10. Mod Neophyte redwudz's Avatar
    USA
    RAID 1 will give you some redundancy. If one drive fails, you can replace it and rebuild the array. But it also will run slower than a single drive and I see no advantage with that. Just a waste of a extra drive. If you needed backup, it would be more efficient to just use a single boot drive and a program like True Image or Ghost and put the backup on a separate disk or on a few DVDs.
    But if you really want to, you should be able to image the original boot drive and put it on a RAID 1 setup. But it would be easier with less problems to just do a fresh install of the OS. And I would also keep a spare drive handy if one in the array dies.
