    Feb 2008
    Belgium
    I'm someone who records a lot of movies, and I deciced to put all my videos now on my pc. I've more than 100 Hi8 and DV tapes, and with my new cam I also have a lot of Full HD recordings in AVCHD sony format.
    I've noticed that none of my pc's at home is powerfull enough to quickly edit al my recordings and burn them on Blu-Ray.
    So I've assembled a PC that I will use to import, edit and export all my recordings.
    This is the config:
    CPU: Intel Core 2 Quad Q6700
    Mainboard: Asus P5E WS Professional
    RAM: GeIL DIMM 4 GB DDR2-1066 Kit (GB24GB8500C5DC, Black Dragon Series), 2*1GB
    HDD: Western Digital Raptor WD1500ADFD * 4, in Raid 0
    Gra. Ca.: GF8800GTX XXX 768MB or GF8800GT Super+ 1024MB
    Blu-Ray burner: LG GGW-H20LRB
    PSE: Tagan TG700-U33 2-Force II 700 Watt
    Case: Chieftec CX-05 B-B
    Screen: SyncMaster 245B 24"
    OS: Windows XP Pro or XP x64
    The software I will use is: Pinnacle Studio 11, Picture Motion Browser Sony, Nero 8, Sony Las Vegas Studio
    Can you tell me wich parts I should change and your general opinion about this config.
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    The video card is about as overkill as you could possibly go. You can get away with a cheap card for what you're doing.
    Also ditch the RAID 0 and never ever even think about it ever again. You should run one in those as your boot drive with your apps on it and get some other larger drives for the actual work. I think two extra drives would work of sizes large enough to support your scratch footage. Transcode back and forth between drives as needed. I doubt you'll exceed the data bandwidth of that platform with any SATA2 drives. The increased rotational speed of the Raptors really only help your seek times so they're best suited for boot volumes on workstations. With the amount of memory you're putting in you'll have enough cache space when working with Vegas.
    FB-DIMM are the real cause of global warming
  3. Member Soopafresh's Avatar
    Jan 2004
    XP 64 has problems with some codecs, especially Quicktime
  4. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    I missed that. XP Pro is great but do keep in mind that you won't see the entire 4GB of memory but more like 3.7-something. Not that this will inhibit your editing. Vegas will use a sizeable amount but adding more would also be overkill.
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You will also want to adopt a backup system for storing your original files. The best solution at the moment based on cost, would be additional HDD's. You could access them using removable trays or use external cases. If you use external cases, you will want to use firewire or eSATA for greater transfer speed.
    Aside from the video card overkill and Raptor/RAID issues noted above, everything else looks good.
    Google is your Friend
