  1. I need to adjust the playback speed on an .avi (divx 4).
    Quicktime Pro's slider isn't precise enough for my needs, and I need to be able then drop the file into Visual Hub (or just use visual hub to change it if possible).
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    Are you just talking about the Playback of the file in the Player,
    or about adjusting the speed of the frames in the file itself?
    IF you adjust the Playback of the file in Quicktime Player, it will
    not transfer over into Visual Hub. It will still play normal when transferred
    to Visual Hub.
    If you adjust the speed of the frames, also known as undercranking,
    you will affect the file itself and make the whole file play faster,
    because your are adjusting the timing of the frames.
    FCE and FCP can do this, I haven't used iMovie in a long time
    to know if it will allow this.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. I don't know the terms. The video plays too slowly..endoded as if in slow motion. (not drasticly mind you...it's just a tidge too slow).
  4. Member terryj's Avatar
    oh, ok. so the video itself moves slowly,
    and motion within the video is slow
    ( like people taking longer than normal to
    talk or move), but playback ( progress of time, ie. the clock)
    counts as normal in the player (VLC, Quicktime Pro)?
    then you would need to re-adjust the speed of the frames
    as I described above.
    Urban Mac User
