Hi,
My new PC has a DVB-T PCI card in it which I'm going to use to record UK Freeview broadcast movies and then output them to DVD.
I'm not bothered about editing out adverts, but I do want to trim away the 'start 5 mins early and end 5 mins late' recording time buffers so the video starts at the beginning of the movie and ends at the end of it.
The TV card records in MPEG-2 DVD format so I don't need to convert the source, I just want a bit of software to snip the start and the end, allowing me to select a specific frame (jumping to an I Frame if that's needed), and not mucking up the audio-sync or the integrity of the MPEG-2 compliance.
Which software do you guys recommend? One of the programs I used mucked up the MPEG-2 compliance (can't remember which), another crashed, and a 3rd put the audio out of sync !! Surely some quick to use software preferably (but not necessarily) freeware can do this to a high standard?
Thanks all.
Have a look at what Womble have to offer.
MPEG-VCR is probably best for what you want - best of all it stream copies so there is no coding to worry about and it is , therefore, very fast.
I use it to cut ads out (as well as trim start/end buffering) with excellent results. The only downside is that it's payware but at $35 (US) and a free trial I think it's good value -
Thanks.
I was just looking in the tools section and spotted Cuttermaran and Mpg2Cut2, anyone used them? Any good? -
I use Cuttermaran and it works good, but requires elementary streams. It has a nice "quick jump" feature. I see you're on W2k so you should know that it requires the .net framework if that matters to you.
I've never used Mpg2Cut2."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Thanks guys.
gadgetguy - actually I'm on XP, those PC specs are ages old, I'll update them now... (done!)
How do I rip a DVD, trim part of it (beginning & end), and copy onto DVDs?
By aple in forum Newbie / General discussionsReplies: 5Last Post: 11th Jul 2011, 18:04 -
Trim MP4/H264 video? Want to remove the start and end - how?
By the loc-man in forum MacReplies: 11Last Post: 2nd Nov 2010, 10:12 -
How do I clean up (trim) beginning and end of DVD?
By perceptionist in forum EditingReplies: 6Last Post: 28th Mar 2010, 00:29 -
DVDShrink Start/End
By chronic777 in forum Authoring (DVD)Replies: 7Last Post: 22nd Jul 2008, 12:30 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49
