I have a lot of wmv files in 4:3 format, and am tearing my hair out trying to convert them to DivX or Xvid with an aspect ratio of 16:9.
I've tried using AVS video converter and Riverpast Videocleaner Pro, I've altered the pixel-size in the DivX codec from square to 16:9 PAL, I've used MPEG4Modifier, I've tried everything I can think of..
BUT although on the PC the aspect ratio change is recognised by VLC player, when I put the converted DivX files on DVD, my standalone DVD player(s) ignore it and I get the bars down the side as it happily displays the original 4:3.
Any ideas greatly appreciated.
Since your Divx/DVD player is ignoring the DAR flag you will have to crop/resize/reencode the video so that it is 16:9 (for example, 704x400) with square pixels, as OkeN suggested.Originally Posted by steve_hawthorn
AviDemux will let you crop/resize while it converts your WMV to Xvid. Press the Filters button in the Video section of the main window.
As far as I know, it doesn't allow you to use external encoders (it has many built in) so you can't use Divx. This shouldn't be a problem because Xvid is mostly compatible with Divx. Just be sure not to use features you player doesn't support (this is true when using Divx and another program too). Frames over 720 pixels wide or 576 pixels tall, GMC, and QPEL are often not supported by Divx/DVD players.
You might find this site useful:
http://www.jarnot.com/twiki/bin/view/Public/DVP642LisaBsAVIGuide
It deals mostly with the Philips DVP-642 but much of it applies to other players too. -
Thanks for all your help - I'm making progress, but not quite there yet
When I play the original wmv (672 x 544) in VLC player and pump it out thru S-Video to the TV it is slightly letterboxed so the characters look Ok ;
when I play my re-encoded Xvid (704 x 400) on my standalone it fills the screen so the people look stretched - very tall and skinny ;-(
BTW, the reason I'm doing this is to give the progs to someone who doesn't have a computer.
WMV Aspect Ratio Changing?
By Crazyj32 in forum Video ConversionReplies: 11Last Post: 10th Aug 2014, 07:53 -
Changing aspect ratio for WMV?
By vato76 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2010, 10:27 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 13:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 06:40 -
Changing an aspect ratio on DIVX
By diablo_jones999 in forum Video ConversionReplies: 13Last Post: 29th May 2007, 12:53
