I have captured some footage from my VHS player through my camcorder to my hard drive. I have 10 or so avi clips on my hard drive that are all 720x480. I want to put these files on a DVD and watch them on my TV. Should I resize the files in Virtualdub to 640x480 so they won't look squished on the TV, or should I leave the file sizes like they are?
Thanks,
Opti
DVD doesn't support 640x480. Encoding choices* are
720x480
704x480
352x480
352x240
For VHS leave as 720x480 or use 352x480 for less important material when encoding to MPeg2 for DVD.
For bit rates try 6Mb/s VBR for 720x480 or half that for 352x480.
*See https://www.videohelp.com/dvd and https://www.videohelp.com/calcRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
640x480 VHS capture looks stretched on 50+ inch HDTV
By jrru2 in forum Capturing and VCRReplies: 11Last Post: 4th Nov 2011, 21:53 -
Should I use 640x480 or 320x480 with cubic for VHS capture
By groove365 in forum Capturing and VCRReplies: 4Last Post: 1st Sep 2010, 01:23 -
How to resize 1080p in Virtual Dub to 720x480
By mlong30 in forum EditingReplies: 5Last Post: 31st Jul 2010, 18:57 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 05:50 -
How to convert 640x480 to 720x480 ?
By webstar in forum MacReplies: 3Last Post: 8th Jan 2008, 09:44
