How can I remove the video stream from an avi file and make another avi file with video only, no audio?
In VirtualDub: menu "Video" --> direct stream copy,
menu "Audio" --> no audio, menu "File" --> save as AVI.
AVI-Mux GUI can do the trick as well. -
TX
I don't see any Audio menu in VirtualDubMod even after opening the avi file. Why is that?
I couldn't figure out how to use AviDemux.
AviMux http://aubrun.jeanpierre.free.fr/avimux/avimux.html worked on a small test file, but demuxes only 39min of the 90 min avi file. Clueless.
I'll try out Avi-Mux GUI
it's under 'streams'->'stream list'I don't see any Audio menu in VirtualDubMod even after opening the avi file. Why is that?
If I disable the stream list, will demux the videoit's under 'streams'->'stream list'
TX
If I click on the speaker it gets dimm. What does that mean? -
it means audio playback is disabled upon preview.Originally Posted by GeeForce11
Help me automating demux-remux dual audio files...
By CactusMan in forum Newbie / General discussionsReplies: 8Last Post: 6th Jan 2012, 21:59 -
Demux and cut mp4 files?
By kewlar in forum EditingReplies: 0Last Post: 30th Sep 2010, 17:51 -
How to demux .m2ts files in OSX???
By bendermac in forum MacReplies: 11Last Post: 19th Jan 2010, 23:08 -
Demux Matroska files
By Anicsi in forum MacReplies: 4Last Post: 16th Dec 2009, 13:41 -
demux avi
By kirti in forum ffmpegX general discussionReplies: 3Last Post: 4th Jan 2009, 17:14
