I have used WINdv but the problem is it saves DV to AVI and ends up behing something like 10Gb per hour...
How can I, or what can I use to make the file smaller?
I have 4 tapes of 90 minutes that I need to put on a DVD DL 8.5GB....
How can I acheive this?
Thanks for the help.
DV is high quality because it's lightly compressed. Hence the files are very large. If this video is important to you, break it down into 4 or 8 GB chuncks and back them up on DVD.
If you just want something to watch, convert to MPEG2 for movie DVD. 360 minutes is a bit much for a single DL DVD unless your video is very clean (low motion, low noise). You'll want a 2-pass variable bitrate encoding at about 4000 kbps. Use an bitrate calculator for a more exact value. Do you have an MPEG2 encoder? -
If you want an all-in-one (not the best quality and on the slow side, but ok) you can try Ulead DVD MovieFactory. It comes with a lot of DVD burners so you might already have it.
MPEG2 to H.264 Conversion question
By tonyaldr in forum Video ConversionReplies: 19Last Post: 5th Apr 2012, 09:06 -
MPEG2 Compression - Question
By b1tbull in forum Video ConversionReplies: 3Last Post: 2nd Jul 2010, 04:14 -
Strange Mpeg2 Conversion Question
By mohawkcr in forum Video ConversionReplies: 1Last Post: 5th May 2010, 21:34 -
Question about which is more clear, mpeg1 or mpeg2?
By jimdagys in forum Newbie / General discussionsReplies: 12Last Post: 25th Sep 2008, 02:08 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 09:45
