I have a two year old sony wega hd tv that has always recieved local channels in hi def (digital) and now not one is working. Regular channels come in as always. What could be wrong.
Antenna or tuner failure.
Are you sure the antenna is pointed at the transmitter?
Did you try to rescan channels?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I didn't try to rescan yet. I will give that a try right now. I was thinking more of the tuner failure and how to replace it if the rescan doesnt work. Thanks edDV
Best way to connect PC to SONY Trinitron Wega FD CRT TV
By snsd in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2011, 09:07 -
Are there any home fixes for screen burnins on sony wega hdtvs?
By yoda313 in forum Newbie / General discussionsReplies: 6Last Post: 21st Aug 2010, 18:06 -
Sony Grand Wega/Blu-Ray Set up
By mngwdw in forum DVB / IPTVReplies: 8Last Post: 16th Dec 2008, 14:05 -
Problem with Sony Wega KDF-E60A20 ??
By ofield1 in forum DVB / IPTVReplies: 1Last Post: 10th Mar 2008, 10:45 -
Laptop Via VGA -> Sony Wega LCD Via??
By ceilos456 in forum Software PlayingReplies: 1Last Post: 22nd Aug 2007, 19:23
