Hi guys,
I am having difficulty converting FLV files to wmv using Total Video Converter 3.11. Ive tried auto, wmv1 and wmv2. Sometimes TVC converts them but most of the time it just crashes immediately when i click convert or after about 1 second into the conversion. Same thing when i try converting to mpegs - sometimes works but mostly crashes.
Its really annoying having to try converting over 40times to get it to work. Not sure what the problem is, only thing i can think of is it may not be fully compatible under vista. Anyone else have issues with crashing as well?
thanks for the help
Results 1 to 9 of 9
just tested super did not work for me. Keep getting errors. Super mentioned it has errors working in Vista. Anyone else encounter this?
used: output (wmv), codec (wmv8), audio codec (wma)
video: 720 * 480, aspet 3-2 and didnt change anything else
tested with directshow decode and without. any tips? -
try doing this
super, resolution NO change, fps 25, container output extension MP4
codec mpeg4,
video bitrate 576
when you get that file which will be akin to a stream copy, as far as quality and frame rate
now you can convert that to anything you want
super will NOT upconvert/transcode flv to a higher res
for FLV files its much better to use an intermediate format of the SAME resolution
unless you want to go the avisynth route sugested above
Total Video Converter stops at 4GB
By texas1 in forum Video ConversionReplies: 2Last Post: 21st May 2010, 10:31 -
By callmeking in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 18:51 -
Total Video Converter filesize limit
By ashoun in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 17:40 -
Total Video Converter problem with wmvs
By majax79 in forum Video ConversionReplies: 5Last Post: 23rd Nov 2007, 01:33 -
Problem with Total Video Converter
By supaduparocka in forum Video ConversionReplies: 0Last Post: 16th May 2007, 06:26
