hi, im trying to capture tv shows from my hdtv using a dazzle but i cant get it 2 show up on my comp. i had no probs when i did it with my reg tv i had but i think its not showing up because when i plug the video wires and stuff into the tv it sad i pluged something into av1 w/e that is does anyone know whats the prob and y i cant see video on my pc?
sorry about my english im alittle slowlol
Results 1 to 13 of 13
Are you sure the HDTV has a video out?
If it does it is probably only outputting from the analog tuner.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
whats that mean im not rly a tv pro lol does that mean i cant do it or i have to change something ?
Yout HDTV probably lacks a video output. Do you have a cable box? Capture from that or just use a VCR.Originally Posted by zookeeper525Recommends: Kiva.org - Loans that change lives.
so i need a video output 2 do it.
http://www.bestbuy.com/site/olspage.jsp?skuId=8260552&type=product&id=1170289358105
thats my tv i dont know what im looking for do u know if it has it -
it said it has Outputs: 1 A/V, 1 optical digital audio
is that what i need -
Connecct to that. See what it does.Originally Posted by zookeeper525Recommends: Kiva.org - Loans that change lives.
it works for my cable tv but when i tried 2 capture gameplay from my xbox 360 it said it had a invaild signal i thought it was because i had 720p turned on
for my xbox so i turned it off but it still does it would it e because i have the audio cables from my xbox pluged into my pc speakers would that mess up the signal or something else is at work -
The Dazzle only works for 480i.
i know i changed it back 2 480i but i still get the the invalid signal do u think its because my audio cables r not pluged into my tv? would that make the signal invalid
I don't know. You just need to experiment.
well i tried the audio cable in my tv and its still coming up as an invaild signal does anyone know what would do this i have the hd wire from my xbox set 2 tv and its still coming up as an invaild signal on my pc
I was just got a dazzle and i also have an HD tv and an xbox. I checked on Youtube for the best system to use cus i heard you should use a Distribution Amplifier but whatever. I found a post by lbcjustin about it and he said you can't use hd xbox with dazzle, and the best thing to do is get an xbox 360 s-video cable. For the best quality get two "RadioShack® Gold Series 6-Ft. A/V Cable with S-Video", a "Distribution Amplifier" from radioshack as well, and you can can google this cus i found it on xbox.com and it's the "Xbox 360™ S-Video AV Cable", i bet you can find it at a better price than $30 from xbox.com. So i hope this helps. If you want the cheaper method, takeout the distribution amplifier and buy only one "RadioShack® Gold Series 6-Ft. A/V Cable with S-Video" to connect from the tv straight to the dazzle instead of through the DA.Originally Posted by zookeeper525
Other products like the dazzle?
By darklink502 in forum Video Streaming DownloadingReplies: 3Last Post: 19th Mar 2012, 21:47 -
Dazzle Video Creator Plus Help Please!
By FragpooL in forum Capturing and VCRReplies: 1Last Post: 23rd Jun 2011, 23:51 -
Pinnacle Dazzle. Need help!
By s3r19lk1ll3r in forum Video Streaming DownloadingReplies: 3Last Post: 7th Oct 2010, 15:11 -
Video to Dazzle and Tv
By fellixombc in forum Capturing and VCRReplies: 1Last Post: 6th Jul 2010, 15:52 -
Problem with Dazzle
By brad1983 in forum Capturing and VCRReplies: 1Last Post: 17th Jun 2010, 12:20
lol
