Hello,
I recently converted my home movies from VHS to DVD using a standalone DVD Recorder. I then ripped the DVD using Magic DVD Ripper to my hard drive. I now have several avi files that I want to cut into pieces for editing. I was able to do this using Virtual Dub but I noticed that when I saved the AVI file the pieces are larger then the whole AVI. I am thinking it has to do with the compression I used (Xvid). I used GSpot to see what codec was used on the original AVI and it is also Xvid. Shoud just cutting a AVI result in all the cut pieces being the same sixze as the original AVI?
Am I doing somethingg wrong? Is there a better program to use to cut the AVI and also remove scetions of it?
Each AVI file has its own header so the sum of 10 clips will be a tiny bit bigger than the 1 source file. But I suspect you rerendered the file with a higher bitrate.
Put VirtualDub into Video -> Direct Stream Copy mode. Segments you save must start on key frames though.
If you use one of the lastest versions of VirtualDub you can use Video -> Smart Rendering. Then you can cut anywhere you want and only cut GOPs will be rerendered. -
I am using VDub 1.7.8 and just found the Smart Render option which greatly reduces the files size when cutting. I guess this brings me to another question when suing Smart Render do I use Full Processing or Direct Stream for the video?
Also for the audio I get that message when I open it about the VBR should I use Direct or Full Processing for the audio? If using Full what sould I set the Audio compression at? GSpot says the orginal is MPEG -3 44 kbs but that option is not available in VDub, I only have 40 or 48 kbs -
Since VirtualDub's handling of VBR audio is borked you will have to reencode your audio. Use Audio -> Full Processing Mode, Audio -> Convert (if necessary), then Audio Compression. I use the Lame ACM codec, 48 KHz sampling, 192 kbps or 224 kbps.
ripped dvds when converted to avi out of sync
By angryassdrummer in forum Video ConversionReplies: 3Last Post: 9th Jan 2012, 06:43 -
Trouble with Ripped DVDs/converting .VOB to .AVI
By research in forum Video ConversionReplies: 1Last Post: 15th Jul 2010, 15:42 -
Noob question about converting ripped files to AVI
By gingerman74 in forum Video ConversionReplies: 4Last Post: 20th Mar 2010, 23:39 -
Ripped TV shows from drive to individual avi
By bear2616 in forum Video ConversionReplies: 1Last Post: 22nd Nov 2008, 21:23 -
ripped dvd's to avi, which route?
By ojfish247 in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2008, 19:21
