Hi all, can you help? I have a cable modem connected to a D-Link di-524 router, this is connected to my PC upstair via the ethernet cable, I also have a laptop that connects to the D-Link wirelessly, all is workink fine. I have a pc, xbox360 and now a networkable AV- reciever all with ethernet connections on the rear, I have been given a NETGEAR wireless ADSL router, I do not intend to use the ADSL part of it. How do I get the NETGEAR to talk wirelessly to my D-Link to enable me to connect my pc. xbox and receiver to the net???? Can anyone help? Thanks
a cat5 cable from the dlink to the netgear is the only way i an think of.
Unless you set the second router as a pass-though device, you might have some problems. The problem lies in the fact that both routers act as a DHCP server. When you have two DHCP servers on the same net, you usually have connectivity issues. The more practical method would be to use a switch instead. The switch would not dole out IP addresses.
Believing yourself to be secure only takes one cracker to dispel your belief.
Question about routers
By tcory in forum ComputerReplies: 7Last Post: 19th Jan 2011, 19:43 -
Top rated wireless routers
By neworldman in forum ComputerReplies: 8Last Post: 6th Sep 2010, 03:44 -
Wireless N routers 150mbps vs 300mpbs
By WinSpecToR in forum ComputerReplies: 5Last Post: 16th Aug 2009, 04:04 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56 -
USB Wireless lan stronger than Internal wireless?
By Super Warrior in forum ComputerReplies: 11Last Post: 7th Aug 2007, 00:26
