Hello,
My department in the university uploads MP3 files of each lecture. It's only audio, and each lecture last for about 100 minutes. Right now, the MP3 is mono, and the avarage size of the file is 70MB. Is there any way to make these audio files smaller in size, and still get a good quality? What would you recommend?
Thanks!
Do you only play them on your computer? Or do you put them on a music player which only accepts mp3? If you only use them on your computer, you could use better formats like OGG Vorbis or HE-AAC
Touchy sensitive dude :D. -
I can't agree with jagabo's recommendation because while it will work, if someone needs to upconvert the KHz, say to burn it to CD audio, it will sound like absolute crap. My recommendation would be to leave it 44.1 KHz for CD audio compatibility and drop the bit rate to 96 or even 64 kbps if you must. I cannot personally recommend going below 64 Kbps.
While Denizzje's suggestion has some merit, the problem is that idiot users will have no idea what OGG or AAC are. You'd probably do best to leave them as MP3. -
His files are already at about 96 kbps. What I recommended works pretty well for voice recordings and is roughly equivalent to 128 kbps with 44.1 KHz sampling.
However many idiots have already heard .MP4s on their gayPods.
I'd suggest NeroAACenc for producing 64kbps LC-AAC or even 32kbps HE-AAC,
given that the MP3 sources are mono. -
Use VBR MP3 if you aren't already, gives a bit more quality for the same average bitrate.
If you are starting from a fairly compressed file, any recoding will give you a noticeable quality hit.
But it is a lecturer droning on, not chamber music, so a really low rate may be acceptable.
Full HD camcorder + MIC Input for recording Lectures
By AjnabiZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 16th Apr 2016, 11:49 -
By AjnabiZ in forum Capturing and VCRReplies: 0Last Post: 20th Feb 2011, 21:46 -
Convert WMV2 / WMV8 to another format. Any recommendations please?
By NotHarry in forum Video ConversionReplies: 4Last Post: 25th Apr 2009, 12:13 -
Mp3 payer recommendations
By GJF in forum AudioReplies: 14Last Post: 6th Sep 2008, 09:10 -
simple car audio (mp3,wma) player recommendations
By trpenner in forum AudioReplies: 0Last Post: 4th Dec 2007, 16:50
