I recently had a rather surprising result to an experiment. I've tried using several capture programs to capture video signals fed through my VCR to my Sony Handycam to my computer via Firewire, none very good quality. I used the camera's built-in analog-DV on the fly convertor. Then I tried recording the signal from the VCR to an 8-mm tape (in the Digital 8 format) and then using Scenalyzer Live 1.3 to capture THAT feed. The result was far higher quality. Is this just a higher quality capture program or does this technique somehow yield better results? I can't understand how it can improve the results if the camera is essentially doing the same thing (it should degrade, if anything). Any clues? Thanks.
Results 1 to 1 of 1
Vid Caps
By moonshadow in forum Video Streaming DownloadingReplies: 5Last Post: 22nd Feb 2012, 09:31 -
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 15:38 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 22:06 -
My Caps Come out very Blurred
By zxfactor in forum Capturing and VCRReplies: 9Last Post: 17th Feb 2009, 06:10 -
Capture JPEG Screen Caps From DVD
By philly33flyers in forum DVD RippingReplies: 10Last Post: 25th Aug 2007, 11:48
