I had transcribed subtitles from a video of a degraded print with subtitles on the print itself (quite eye-straining in some scenes with white background) and was able to sync them up to a better version. I noticed a subtitle I missed and I wanted to change the font to something bigger (I used Arial Narrow). When I opened the .srt file that I muxed with the video and audio in DVDAuthorGUI, I found the timings were off from the timings on my final DVD itself. For instance, one line that should occur at 58:37 according to the subs occurs 2 seconds later on the film (in sync). I then ripped the subs from the DVD with VSRip and converted it to a new .srt with SubResync and found the timings to be identical to the original .srt. There are no problems with the sync on the final DVD. How accurate is PowerDVD's timing? This is what I used to look at the film to check the time against the subtitle file. Since the timing of the ripped file is the same, I don't think something happened during the multiplexing to add two seconds to my video/audio/subtitles.
Results 1 to 1 of 1
Extracted subtitle timing problem.
By Orange-kun in forum SubtitleReplies: 0Last Post: 2nd Mar 2011, 13:20 -
auto timing for subtitles any software
By userwords in forum SubtitleReplies: 0Last Post: 30th May 2010, 19:34 -
Syncing timing with additional subtitles?
By architectofpain in forum SubtitleReplies: 0Last Post: 6th Mar 2010, 02:16 -
Timing Subtitles from xls to srt
By tambor in forum SubtitleReplies: 3Last Post: 24th Feb 2010, 06:35 -
subtitles timing
By teamo1976 in forum SubtitleReplies: 3Last Post: 21st Dec 2009, 16:58
