Got a sent a home made dvd-r, on a cheap crap media, CMC MAG AE1. This plays on my standalone, with freezes every now and again, that I overcome by speeding up over the freeze and it then continues. I copied it with shrink onto my hdd, and burned onto a TY, hoping to have filtered out the freezes. Same thing at the same points with the re-burn. They do not freeze on the computer though. Shouldn'd the re-burn have ironed out the freezes, and is there a better way to do it ?
How old is this home player, and has it happened with others.
Also confirm the frame rate of the dvd, and make sure your home dvd player supports it, otherwise problems can occur. -
Try Decrypter, ISO read, ISO write, if you have Decrypter. There's ISO Buster too.
Hmmm, PC playback OK, so what would cause a standalone to stutter but not a PC? I would check for bitrate spikes, perhaps demux and remux.
The file you copied to the HD from the suspect media works just fine. Media eliminated.
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 18:27 -
MEGui FREEZES!!
By mark63534 in forum Newbie / General discussionsReplies: 0Last Post: 23rd May 2010, 21:43 -
AVI Freezes up
By surffx in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2010, 06:49 -
XP freezes momentarily
By sdlehman in forum ComputerReplies: 12Last Post: 11th Aug 2008, 17:01 -
Vcd freezes
By notebookguru in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Dec 2007, 16:00
