  1. Member kippard's Avatar
    Dec 2005
    I ripped a DVD w/ DVD Decrypter. How can/should I extract a lossless segment? Thank you!
  2. Hi-
    One way is to open the VOB containing the segment you want in MPEG2Cut and use the [ and ] buttons to isolate the section you want, before saving it. There are lots of other programs that can cut VOBs, though.
    If you want an entire chapter, you can use DVD Decrypter on IFO Mode and select just the chapter you want.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    You could also use Womble or VideoRedo, or use DVD Shrink in re-author mode to isolate the section you want into a single VOB, then use VOB2MPG to extract it.
    What do you need the segment for, and in what format ?
    Read my blog here.
  4. Member kippard's Avatar
    Dec 2005
    What is the best format for a lossless extraction, MPEG2? MPEG2 would be fine. I want the audio preserved, mostly. Thanks again!
  5. Member Seeker47's Avatar
    Jul 2005
    What's wrong with just using Shrink in re-author mode for the extraction ? That's lossless, isn't it ?
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  6. Member kippard's Avatar
    Dec 2005
    I used DVD Shrink on Re-author, but I had to load a DVD Decrypted VIDEO_TS - for some reason DVD Decrypter on IFO Mode could not see the second feature, the one from which I wanted to extract a scene (2 films on one DVD). Neither could DVD Shrink in Re-author mode see the second feature looking on the original disc. Good helps. Thanks all!
    Apr 2004
    Miskatonic U
    DVD Shrink cant extract the video (i.e. it can't demux). What it can do is give you a VOB structure with just the sections you want in them, after which you can demux with a different tool.
    Read my blog here.
