such as .avi, .wmv and .mkv
but to encode them into a DVD VIDEO_TS folder, without losing any quality whatsoever.
Is there a system or way of doing it whereby it's easily done?
I mean easily, as in as simple as ripping and burning a dvd
First see "What is DVD?" above left.Originally Posted by urb1972
https://www.videohelp.com/dvd
DVD must be MPeg2 at specific sizes and bitates.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
You will lose a little bit of quality with any conversion. If the source file(s) are of high quality, it will hardly be noticeable. FAVC is high on my list. It isn't as easy as a one click solution, but it walks you step-by-step.
Very intuitive and nice results.
This is from the author's homepage.
FAVC is a GUI that enables you to easily make DVDs from video files. It takes one, or more, video files and produces a dvd folder ready to be burned to a dvd disc that should play in any regular dvd player. FAVC uses several pieces of free software to accomplish its task.
Features:
Input video files and obtain a DVD folder ready to be burned to a DVD disc.
Automatic file recognition and analysis.
Automatically assigns correct bitrate based on disc size chosen.
Easy chapter creation.
AC3 Retention.
Uses Muxman (Via BatchMux) for DVD Authoring.
Automated Menu Generation for up to 8 Titles.
Two requirements:
1) Must have Avisynth v2.56a, or later, installed. (2.57 Recommended.)
2) Must have the .NET framework Version 2 installed.
Instructions:
Open FAVC. Choose your video files, configure the options and then click the generate button. Whilst processing, tasks will run on the task bar and can be watched. The main task is video encoding, which is done by QuEnc 0.72 or HC 0.22.0.0. When everything is done you will have a dvd folder in the required directory.-The Mang -
Lose of quality = always (depends on source as to how much)
Avidemux, is in itself, complete, no need net installed.
I cant say if avidemux handles wmv, but
Wmv > windows movie maker > out as dv avi > convert from here with avidemux
Output as dvd, have not used this feature as yet, but will ge around to it.
Burn output using imgburn
Cost's nothing, but a bit of time
Well, that will depend on your system ... you have listed a cpu at 400mhz, if true, its going to take a lot longer to complete the tasks involved.
LINUX: AVI to DVD Encoding and Authoring : BASIC
By disturbed1 in forum User guidesReplies: 13Last Post: 5th Feb 2010, 21:43 -
DVD authoring from multiple sources?
By architectofpain in forum Authoring (DVD)Replies: 9Last Post: 25th Oct 2008, 00:34 -
Program for basic DVD authoring
By netimen in forum Authoring (DVD)Replies: 7Last Post: 11th Jun 2007, 20:25 -
Very Basic Authoring Question
By Seeker47 in forum Authoring (DVD)Replies: 7Last Post: 10th Jun 2007, 21:24 -
Basic Application to create .psd buttons for Authoring?
By Moontrash in forum Authoring (DVD)Replies: 12Last Post: 24th May 2007, 07:12
