I forgot, can someone tell me where does dvdshrink dump it's files. If I want to clean out my harddrive, I remember that dvdshrink leaves behind the ripped files. I have vista 64 bit & I cannot find the location where those files are stored and left and i wan to clean it up. Thanks.
Results 1 to 16 of 16
By default it's somewhere in "My Documents", as far as I can remember.
Try doing a windows search for files with the extension .VOB - that should help you narrow it down. -
Thanks but i dont mean that, i mean after you rip a movie, the files are left over of what was ripped. I want to find them & clean them up. Dont know how to explain.
Do you mean the files it creates after analyzing a movie that you are going to shrink? I'm not sure where they would be located in Vista, but in Windows XP I think they are located in C:\Documents and Settings\All Users\Application Data\DVD Shrink.
So you might want to do a search on your computer for any folders called DVD Shrink, and see what that comes up with."Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
DVDShrink does not leave any temporary files behind. The original video files (that you open with DVDShrink) are still there. I guess the easiest way to find where they are would be to use Windows to search for folders "VIDEO_TS". This search will show all the original videos and the ones shrunk by DVDShrink and you can figure out which one is which.Originally Posted by mn072065
shrink does leave small randomly named files on your computer. they are used in case you wish to re-do a dvd. it is a timesaving device so the movie doesn't have to be re-scanned. they are where j1d10t says. they are harmless.
I would like to add some more info since my previous post is not entirely correct...DVDShrink does not leave any temporary files behind...
1. If you only use DVDShrink to shrink video files, it does not leave any temporary files behind.
2. If you use DVDShrink to also burn the shrunk video files to DVD (with option to use Nero checked), it will leave temporary files behind. The location is set up by the user (there may be also a default one) in the first burning session. To find this location again, use DVDShrink to open a VIDEO_TS folder (<4.7 Gb), then click BACKUP, it will give you a summary with location of the temporary folder. -
ollie that's crap. i've never used shrink to burn anything and i have thousands of files in the shrink data folder.
j1d10t hit the nail on the head. And aedipuss is correct... those files are very small (I have 153 files totaling 17.3Mb) and harmless. They are actually useful so that if you have to go back and make a new backup to replace a broken/scratched backup you will not have to re-analyze the video.
Donadagohvi (Cherokee for "Until we meet again") -
j1d10t that's the location i was trying to look for C:\Documents and Settings\All Users\Application Data\DVD Shrink. but i need it in Vista. Can't seem to find it in Vista. I know the files are harmless and can be useful when ripping again, but i wanted to see how many i have stored and perhaps clean it out. Does anyone know how to find it in Vista, the location. Thanks.
Sorry I can't help there. While I have used computers with vista insalled I don't own a computer with vista on it. Hopefully others can help.
Although I did a quick google search and found this
So you might try looking for folders with those names.Originally Posted by vista article
Good Luck!Donadagohvi (Cherokee for "Until we meet again") -
You are right. I take back what I said about the temp files. I saw 62 files (702 kb) in my folder C:\Documents and Settings\All Users\Application Data\DVD Shrink.Originally Posted by aedipuss
What I referred to earlier are the huge temp files created when one uses DVDDShrink to burn DVD, something that not many people are doing. This will create a huge temp folder. The details are in a DVDShrink guide linked on this site:
http://www.dvd-guides.com/content/view/16/59/
(STEP 6: "The "Select folder for temponary files option" ... is the location that DVD Shrink will put the DVD files before burning them. Make sure the hard disk you select has enough free space and that you remember where they are as you have to delete them manually after the burn.").
I guess someone with Nero installed on the PC may choose this option for convenience. Most others would use ImgBurn for the burning step.
Just for clarification but this is a moot point since obviously this is not what mn072065 talks about. I misread the question. -
Thank you so much, found at Try C:\ProgramData (it's a hidden folder) , this was really bothering me. Thanks alot
To the moderator, sorry for duplicating thread, wont happen again. Thanks all
directshow dump
By jonny plumber in forum Video ConversionReplies: 7Last Post: 12th Jan 2013, 22:04 -
problem with DVDShrink finding files
By chaskar in forum Newbie / General discussionsReplies: 8Last Post: 5th Jan 2010, 17:48 -
dump hd gui
By ShinjiIkari1990 in forum Blu-ray RippingReplies: 2Last Post: 25th Jun 2009, 22:14 -
Video_TS Files (DVDShrink) to DVD
By ione in forum Newbie / General discussionsReplies: 7Last Post: 26th Jan 2009, 23:18 -
Physical memory dump and now stuck on startup screen
By zanos in forum ComputerReplies: 8Last Post: 18th Dec 2007, 11:36
